i have a trunk box dilemma. - Car Audio Classifieds!
Old 08-14-2011, 01:24 AM
Captain Tying Knots
0/11 sssss1220
Default i have a trunk box dilemma.
ok so im lookin to get better numbers out of my sa 12s sealed off from the trunk. the first thing i have been told to try is building a bigger box. but if i build a bigger box i need more port area, but unless i make my box taller i cant fit any bigger of a port in there, and even if i did stuff an extra 2 inches of height in there id only gain 8 sq inches. so would having an optimally sized box facing back be louder than too small of a box sealed off from the trunk? i dont think there is any way i can make the opening of the trunk bigger otherwise i would.
TEAM NWSPL
Old 08-14-2011, 01:35 AM
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
Well first off how big is your current box? Going bigger isn't always the answer. Neither is sealing it off from the trunk, A lot of people don't have good experiences from doing so.
Old 08-14-2011, 01:41 AM
Captain Tying Knots
0/11 sssss1220
its about 1.7 net per sub. other people whove used sa's have told me 2.25-3 works best. i actually did notice an improvement though from when i was testing the box firing back and then sealed it off.
TEAM NWSPL
Old 08-14-2011, 01:46 AM
0/11 sssss6030
1.7 per is a little small, I would do 2-2.5, 3 is too big, How much power are you sending to each?
Old 08-14-2011, 02:54 AM
supadave's Avatar
0/11 ssssss203
i am with the above guy i would do it 2-2.5 max for 12s
what kind of car is it your putting this in an what kinda numbers your doing now.
Old 08-14-2011, 03:12 AM
3rdshiftdiscretion's Avatar
CACO Late Night Crew
0/11 sssss4240
Feedback Score: 30 reviews
Instead of guessing on size why dont you look at factory recommended or the TS specs....
Bewbs
Old 08-14-2011, 10:56 AM
CLNFREAK's Avatar
0/11 sssss1788
Feedback Score: 23 reviews
SUBS ?
CAR ?
MAX DIMENSIONS ? (that will allow you to remove it from trunk...if you are looking to do that... or build it in trunk ?)
MAY 8 2009 ask me about that day !!!!
SUBS (2) 12" DC LVL 5
SUB AMP 1100.1
MIDS AND HIGHS AMPS 2 EXL 400.4
BATTS NSB group 31, XS power d3400
SINGER ALT 350 AMP
TEAM DC
DCSOUNDLAB.COM
SINGERALTERNATORS.COM
Old 08-14-2011, 11:03 AM
Dirtbikerrob's Avatar
0/11 ssssss670
i had 2 sa 12s on 3krms in a 4 cube box.
but since we dont know what power/car/and max dimensions, we cant really help all i know is that the sa subs do better on more power in a smaller box. also i have mine in my trunk subs rear firing and ports to drivers side quarter panel.
Old 08-14-2011, 11:14 AM
CLNFREAK's Avatar
0/11 sssss1788
my level 5 12's will be in less then 3 cubes and 8" aero all firing in to cab (front)... and 9k+ of power.....
so as said above let us know all the info
SUB AMP 1100.1
SINGER ALT 350 AMP
TEAM DC
DCSOUNDLAB.COM
box build in the trunk... kodak314 Build Logs 31 10-30-2011 07:50 PM
anybody got any tips for building a box in the trunk Craig28 Enclosure Discussion & Design Construction Help 11 05-05-2011 11:27 PM
dilemma korey_hofer General Automotive Chat 15 08-02-2010 05:09 AM
How to build a box INSIDE the trunk? westman995 Enclosure Discussion & Design Construction Help 12 06-24-2010 06:48 PM
