"T" shaped port? - Car Audio Classifieds!
Old 08-16-2011, 09:57 AM
0/11 ssssss542
Default "T" shaped port?
So I am planning out my next spl build and I am contemplating a T shaped port. Anyone have experience with this? This will be for burps only and I really don't care for exact tuning. This will be forward firing in a trunk.
By T shaped I mean subs and port on same baffle with port in center. My box is not going to have enough depth for the port so I was thinking of turning it on both sides for extra length. This is the same concept of a L shaped port, but rather than being on the edge of the box, it will be center and L'd in both directions internally.
Discuss.
Old 08-16-2011, 10:02 AM
jbizzle's Avatar
0/11 sssss4346
Feedback Score: 26 reviews
You won't necessarily gain more length for lower tuning.
'07 Chevy Trailblazer SS AWD (Garage Queen)
- Alpine 9887
- Eclipse SC8365 3-Way front stage
- Sundown SAX-125.2
'98 Jeep Grand Cherokee (Daily)
- Alpine 9887 (Active)
- Selenium 6" Mids, 4 Crescendo CTS-1 Tweeters
- Sundown SAX-100.4D
- 2 Sundown SA-12s
- Sundown SAZ-1500Dv2
Team Sundown Audio
Old 08-16-2011, 10:16 AM
kmanian1's Avatar
mine>yours
0/11 sssss2130
but he can equalize the compression issues sometimes arise with having a L shaped port in a box that has 2 subs in it.
Old 08-16-2011, 10:23 AM
0/11 ssssss542
I will likely be running NSPL 0-1800 so I don't think I have to worry too much about the loading problems of a L port. But you are correct. IASCA will be running full tilt on my amp and loading may become an issue.
I am not cutting the metal of the bracing behind the seat so a L shaped port would be blocked by the opening into the vehicle if it were on the edge of the baffle, that's why the center is going to be used instead of on the side.
Old 08-16-2011, 10:52 AM
0/11 ssssss484
I had good luck with this build
I gained nicely when I put the L( T )peaces on the port. about .9 . It didn't chang tuning. But it did help with loading
Old 08-16-2011, 10:54 AM
0/11 ssssss484
Old 08-16-2011, 11:28 AM
0/11 ssssss542
Thanks Chris.
Did you do any testing with/without the PVC deflector behind the port? I am going for a similar concept as you have there, but will be flaring the port. I am trying to decide if there should be a wedge on the back wall to smooth airflow within the T. Do you remember how long you made the extensions on the inside of the port?
Old 08-16-2011, 11:51 AM
0/11 ssssss484
Just past the pole vent. I tested the pvc and it was only .2
Old 08-16-2011, 01:31 PM
supadave's Avatar
0/11 ssssss203
i wouldn't do wedges or bigger 45's in the corners. i would think they wouldn't load very well. not better than bendable plywood or pvc pcs. my box will have the bendable wood in mine once i get my 12's rebuilt.
Old 08-16-2011, 06:02 PM
0/11 ssssss542
I was referring to a wedge behind the port opening, not the corners. I will have nicely radiused corners in the back of the box.
I picked up the plywood today. I wonder how impossible it will be to bend 9ply wood for the port flares? I may have to use MDF for the port
"CRX" design . whats this sub forward port back crap?!? maxspl153 Enclosure Discussion & Design Construction Help 20 08-22-2011 10:32 PM
Anyone ever tryed using a port shaped like a T More spl Enclosure Discussion & Design Construction Help 7 04-25-2011 12:30 PM
BUILD LOG Explorer limo 6 IB3s walled 300 cubic feet 50"x12"x3.5" port 15Hz tune kryptonitewhite Build Logs 121 01-31-2011 12:57 PM
[SOLD] Part express 4" "aero" port orangelss Speaker Accessories & Parts 2 10-31-2009 11:37 AM
