WinISD question - Car Audio Classifieds!
Old 08-17-2011, 05:44 PM
0/11 sssssss53
Default WinISD question
I was playing with WinISD today and when it comes to the port it only gives the option for round and square. Anyway for the sub I put in it said a square port should be 4.02 X 4.02 and 16.87 inches long. The box is only 13 inches deep so this would be a slot port, but how do I figure out how to make the slot port the whole width of the box with these measurements. I thought maybe just subtract the width of the wood from the width of the box but that just isn't working with the slot port calculator on the12volt.com. Any help with this would be great
Old 08-18-2011, 02:43 AM
surreal's Avatar
0/11 sssss2489
Im guessing youre missing the fact you can change the measurements for the square port? If your box is 13" tall.. then it would be 11.5 (13 - .75 - .75 for top/bottom pieces of 3/4" mdf). So put in 11.5 by SOMETHING til your number turns green, isnt ridiculous long, and hopefully doesnt have a height:width ratio past 8:1 or so.
Old 08-18-2011, 01:41 PM
0/11 sssssss53
Yes I changed it from round to square and it says 0.15 match. I am sorry as I have never used WinISD before this and this part was really confusing me. I didn't think about changing it myself inside the program I just went to 12volt.com and tried to use their slot port calculator and was having major problems. It is 13.27 deep not 13 tall. The specs are W=21.10 H=32.87 D=13.27. Thanks for the help, I will play around with it and see what I can figure out here. This is the text file from the program
Driver : 12w7
Project by : kanoftuna
Project for : you
Number of drivers : 1
Box type : Vented
Box size : 4.194 ft^3
Tuning frequency : 22.67 Hz
Vent : 1 vent(s)
16.87 in length for each
4.02 x 4.02 in rectangle
Relative
Freq Gain SPL
[Hz] [dB] [dB]
20.00 -3.86 82.34
25.00 -0.45 85.75
30.00 -0.10 86.10
35.00 -0.05 86.15
40.00 -0.01 86.19
45.00 0.02 86.22
50.00 0.04 86.24
55.00 0.05 86.25
60.00 0.06 86.25
65.00 0.06 86.26
70.00 0.06 86.26
75.00 0.06 86.25
80.00 0.05 86.25
85.00 0.05 86.25
90.00 0.05 86.25
95.00 0.04 86.24
100.00 0.04 86.24
Old 08-18-2011, 09:29 PM
surreal's Avatar
0/11 sssss2489
Why do you have such odd box measurements? If your box is 13.25 tall.. subtract 1.5" for internal height of a vertical slot port. Plug in 11.75 (your answer) into the first square port dimensions field, then start with the second 2" wide or so and see the numbers/lengths/color change accordingly.
Old 08-20-2011, 09:50 PM
0/11 sssssss53
I was wondering about the measurements myself but that is just what WinISD gave me when I inserted the information from JL's website on the 12w7. After your first post I did what you said in the second and got the measurements but do you have any idea about why it gave me these box dimensions. I have never used this program so I may have done something wrong but I really don't think I did
WinISD help Scapelli21 Enclosure Discussion & Design Construction Help 0 05-29-2011 04:31 AM
winisd question ltr450racer690 General Car Audio Discussion & Questions 1 05-15-2011 08:18 PM
Winisd question jt_buck Enclosure Discussion & Design Construction Help 4 03-29-2011 10:34 AM
WinISD question osmith Enclosure Discussion & Design Construction Help 4 11-03-2010 08:26 PM
Quick WiniSD Question tntahoe General Car Audio Discussion & Questions 16 10-20-2010 07:49 PM
