Keep my box level/ from sliding! Help! - Car Audio Classifieds!
Old 08-21-2011, 01:32 PM
0/11 ssssss639
Default Keep my box level/ from sliding! Help!
So i will be putting a big box where my back seats used to be, and the plain it will sit on is not level. I need a way to level it off (prob just cut some 2x4s) but I also need a way to bolt it down to something or just an effective way to keep it from sliding forward when i hit the brakes, or side to side on turns.
Old 08-21-2011, 01:34 PM
SPL Distribution Owner
0/11 sssss2983
if using wood to level it, I would go to Fiberglass , Epoxy , Composites, Carbon Fiber - U.S. Composites, Inc. and order Fasco 110 and glue the wood down to the frame of the car. Make sure you sand the frame beforehand.
IT's the strongest glue you'll ever use for stuff like this.
This way you do not have to worry about drilling into areas you can't see the other side of.
Old 08-21-2011, 01:38 PM
0/11 ssssss639
I'll pass on that. Way too much destruction. I was thinking strategic L brackets or something.
Old 08-21-2011, 01:47 PM
bigdhenderson's Avatar
0/11 sssss4981
Feedback Score: 45 reviews
where the seat belts bolt to is the strongest place to fasten something from.
Old 08-21-2011, 03:17 PM
0/11 ssssss639
probably going to grab some L bracket later, along with some more wood.
Old 08-21-2011, 04:43 PM
iamamp3pimp's Avatar
0/11 ssssss661
I always use 3/8" bolts and fender/lock washers to secure stuff in the cabin, and caulk underneath it to keep it from creaking.
Robin Butler
Getting back into the swing of Bass Race after a small hiatus
Old 08-21-2011, 08:18 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
My avatar shows my sub box all the way back against the back seat. There were 4 cargo tie downs and removed the 2 closest to the back seat and spent maybe a few bucks at the hardware store and got 2 long bolts to bolt down the sub box. Guaranteed not to move practically. Using existing seat belt threaded holes or back seat holes would be the way to go instead of doing drilling.
Old 08-22-2011, 05:05 AM
0/11 sssssss45
Thats the same thing I did in my tahoe
Old 08-22-2011, 09:47 AM
0/11 ssssss661
nothing wrong with drilling. in cars you dont have a lot of options.
Robin Butler
whats the difference between a level five and a level four with a level five coil? mattintc10 (DC) 29 02-03-2011 11:12 AM
Box for two Level 4 15"s mcquesten (DC) 5 09-23-2010 09:08 AM
level 5 15 box bread0710 (DC) 1 05-27-2010 08:09 PM
box for 2 DC level 4 18s iikeysound New Member Orientation 2 05-24-2010 02:18 PM
FS/T: DC Level 4 15" D2 and Box whitedragon551 15" Subwoofers 12 09-01-2009 05:21 PM
