6th order design help - Car Audio Classifieds!
Old 08-23-2011, 08:15 AM
0/11 sssss1237
Default 6th order design help
okay so i have a 15 dc level 4 xl, and a crunch gp3000d pro.
basically, im trying to acheive the best score possible and the best loud and low daily driver as well.
i have never built a 6th order but many ported enclosures and one horn..
if someone might be able to point me in the right direction for how to get started, that would be awesome.
also, do you think id be better off in a 4th order or a 6th order?
i have 7.5 cu ft to work with.
Old 08-23-2011, 12:49 PM
surreal's Avatar
0/11 sssss2489
Main issue is DC doesnt have full specs for the sub from what I just checked.
This is a necessity to get accurate results in a design. 6th orders are normally more efficient with better power handling (as you would want with 3k on such a sub) but they are very picky to rear-chamber port area and decently picky on volumes.
I could guess/try to "extrapolate" specs based on the other subs and Q values to get you in the area. It may be slightly risky but has good promise for acceptable results.
A horn is possible and would or could provide additional power handling and output, though most likely not quite to the extent to the 6th order unless it is rather large. I did see you had a lot of space to work with though. This would be the more forgiving design.
The 4th order would be an even harder guess as with these low Q subs they often like small front chambers. You may end up with something really peaky that does OK on the mic, but wont play your lows like you want and definitely wont handle 3k!
Old 08-23-2011, 05:37 PM
HACKMUNCH's Avatar
0/11 sssss3892
shoot me a pm i can help ya.
TEAM TSA 2013
FACTORY BACKED
XS POWER - 4XSPOWER.COM
PSI - PSICARAUDIO.COM
6th order design Vasilios Enclosure Discussion & Design Construction Help 7 06-04-2011 02:42 AM
My 6th Order design Mazdasadc Enclosure Discussion & Design Construction Help 24 04-12-2011 02:06 PM
dd1508 6th order design White91Formula General Car Audio Discussion & Questions 11 11-27-2010 05:37 PM
6th order design need help maybe jmitch Enclosure Discussion & Design Construction Help 0 10-03-2010 06:40 PM
6th order design J&T DESIGNS Build Logs 34 07-15-2010 06:59 PM
