Pros and Cons? - Car Audio Classifieds!
Old 08-24-2011, 02:36 AM
Ajax_6154's Avatar
i want more bigger db's
0/11 sssss2369
Default Pros and Cons?
so i am wondering what are some pros and cons to running sub back port up in a GTI. Main goal is hard hitting daily ground pounder. sub is an EXO15 on a SAZ2500. box will be around 3.8 cubes tuned at 32hz via a 6 inch aero. reason i ask is because i dont think i have enough room to run port and sub back. any input is greatly appreciated.
Vehicle: 2011 VW GTI Autobahn
Deadning: 50sq ft of AT 60, Front Stage: CCX65 on a 1000c4, Sub: Eminent Audio EA1000 10's in 4.9ft3 at 35hz on a BC3500d at 1ohm
i dont like 12's they cant hit the lows like 10's
Old 08-24-2011, 03:42 AM
Zooook's Avatar
1337 M3mb3r
0/11 sssss3991
Feedback Score: 31 reviews
Why not sub up port back?
ALL FOR SALE ALL FOR SALE PM ME FOR PRICES
2003 BMW 330I
2x12" AB HD/W DC XL recones
Old 08-24-2011, 03:44 AM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
Sub up/port side or sub back port side
Old 08-24-2011, 07:27 AM
Ajax_6154's Avatar
0/11 sssss2369
Port needs to be 15" long. Box is 15" deep, there isn't enough room in between the hatch and the port to run external. Port will get choked. I'm just look ing for other options in case I can't bend it.
Sent from my super cool phone using tapatalk
Old 08-24-2011, 07:28 AM
Ajax_6154's Avatar
0/11 sssss2369
Thanks but not an option.
Old 08-24-2011, 07:56 AM
Ajax_6154's Avatar
0/11 sssss2369
i realize its not the prefered method but that is why i am wanting pros and cons. it i can do it another way i will certainly do so but for now (until i no shit design the box) im going with that.
Old 08-24-2011, 12:30 PM
surreal's Avatar
0/11 sssss2489
Could always side fire, or with a slot that works perfectly. If the port needs to be 15" deep, and say its 3" wide.. Make it extend into the enclosure 3" from the rear wall. Should end up ~15" long.
Old 08-24-2011, 12:39 PM
Ajax_6154's Avatar
0/11 sssss2369
this is a 6" aero port. and i already said i couldnt side fire
Old 08-24-2011, 11:09 PM
0/11 ssssss542
Confused as to why you can't side fire a port If you have 15" depth and place the sub on the rear baffle, there should be adequate depth to accomodate the port tube and motor. With of the box will not be an issue either at over 3 cubes.
Side firing slot port with sub back or sub/port back using a slot port would be golden. Not sure why you are hell bent on aero's, especially if you are forced/limited to enclosure design.
Wish I could offer some feedback on Sub back/port up, but I never seen it done before.
Old 08-25-2011, 12:27 AM
Ajax_6154's Avatar
0/11 sssss2369
Ok where to start... I can't side fire the port because the side of the car is in the way... Box is 36" wide vehicle is 38" wide therefore not enough clearance for the port... Not sure if you heard but this is going in my GTI sub on the back baffle would be firing into the seats...not going to happen, I'm hell bent on aeros because with my max dimensions the box is barely 4.1 cubes. If I do a slot port after all displacement and with tuning I want I have less than 3 cubes... Aeros are the way to go.
2 Setup opinions and pros/cons... mcarmer General Car Audio Discussion & Questions 25 05-21-2011 11:43 PM
pros+cons of firing into cab Russellabt General Car Audio Discussion & Questions 12 03-08-2011 07:53 PM
audiopipe pros and cons gbo559 General Car Audio Discussion & Questions 12 07-19-2010 12:27 AM
16+ Volts How To/Pros/Cons? dcmcki General Car Audio Discussion & Questions 48 02-05-2009 09:26 PM
