First Box Build :/ - Car Audio Classifieds!
Old 08-29-2011, 10:59 PM
nicholask1993's Avatar
Dubstep Addict
0/11 sssss1802
Default First Box Build :/
So I learned that I'm not very good at drilling holes straight so in my next box build I'm just going to use 90* clamps and 1 or 2 normal clamps.
Here's what I need to do:
The rear wall is going to be sanded down until it's level with the side walls.
Then the inside is going to be caulked to hell to make up for my lack of craftsmanship.
The front overhang is going to be fixed by using wood putty then smoothing out at an angle using a straight edge.
All other over hangs will be fixed in same manner or sanded down until even.
Get friend to cut holes for subs since I'm not confident in my cutting abilities anymore...
I'm hoping that after I do all that and paint it with some dark gray texture paint you won't be able to see how poorly it was built easily.
On to the pictures...
1998 Subaru Forester
Sony CDX GT-565UP Head Unit
Cadence 6.5" Components
MB Quart Onyx 1500.1
/Surreal
Old 08-29-2011, 11:02 PM
SundownSilverado's Avatar
0/11 ssssss322
I had the exact same problems when I first started building boxes. Just practice till you're good, that's all you gotta do
mads10bass's Avatar
NOT LOUDER THAN YOU :(
0/11 sssss7335
Feedback Score: 36 reviews
not bad man i still mess up every now and again. it happens
WOW
Dubstep Addict
0/11 sssss1802
Though I am happy that I made this box because I learned what does/doesn't work so when I build my next box it will be much better.
Specs:
Width - 32"
Height - 13.5"
Depth - 20"
Tuning - 32hz
Airspace - ~3Ft3 after all displacements
/Surreal
Old 08-29-2011, 11:08 PM
crownvicon26's's Avatar
0/11 sssss1882
Going to be building my first box this week. I will probably have similar results. Thanks for posting this will give me a heads up on what to look out for.
Taramps 8k
2 Zv.3 15's
2.87:1 4th Order @ 48hz
Old 08-29-2011, 11:13 PM
98GCLimited's Avatar
0/11 sssss1921
Feedback Score: 29 reviews
Honestly for a first time that isnt that bad. I have seen some pretty haggard sh*t people have built and not everyone has the best tools to work with either so you gotta do what you can with what you have and honestly once you seal it up with some caulk that box will perform better than any prefab crap you could buy.
Old 08-29-2011, 11:18 PM
surreal's Avatar
0/11 sssss2489
Not too bad really.
Might want to cut all the same height pieces in one pass next time though, little tricks like this can be super helpful and make a big difference.
Also, spend the $100 on a cheap router and table. Get a spiral bit, and a flush bit.
Old 08-29-2011, 11:35 PM
Dubstep Addict
0/11 sssss1802
Originally Posted by surreal View Post
Not too bad really.
I got the guy at Home Depot to cut it one pass I just think that I have it leaning forward some or the glue dried and raised the MDF some.
Was going to pick up a clamp but once I saw prices I decided I'd wait...
/Surreal
Old 08-29-2011, 11:36 PM
mads10bass's Avatar
0/11 sssss7335
you got a local menards? got 90degree angle clamps for 4 bucks a peice and 38" bar clamps for 8 bucks. built a few boxes with em and they work good
WOW
Dubstep Addict
0/11 sssss1802
Thanks, that's what I'm hoping for. The prefab box my subs came in was full of air leaks.
/Surreal
Need help with box build kickerlivinloud Enclosure Discussion & Design Construction Help 16 04-29-2011 08:28 AM
deepsilencer's new box build video designed by james(A.I),build by 99s10walled deepsilencer Car Audio Videos 1 08-30-2010 01:43 AM
how to build a box?? davidrforbus General Car Audio Discussion & Questions 6 02-10-2010 03:46 PM
Box build - [email protected] SPY Off Topic Chat 3 04-24-2009 08:30 AM
