Response graph question - Car Audio Classifieds!
Old 05-02-2009, 02:13 AM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
Default Response graph question
Well as you can tell I am new here. I was in to car audio ~13 yrs ago and am just getting back in to it but I am struggling with a ported box tuning issue. I really have minimal ported experience as in the "old days" we all ran sealed b/c most ported that I had heard at that time were tuned super high and I wanted smoother low end.
I am trying to read a BBP response graph and the box is already built and I am VERY happy with the low end but the upper bass is almost zero.
I believe this problem can be solved by adding more/better components up front or a small sub under passenger side dash? Am I right?
the other question is could I have seen this on the response graph? I seemed to hit my predicted low end but the upper has zero impact? When I look at the graph the upper bass looks flat but what I hear doesn't seem to correspond with what I see
Copy of graph below...
2 Clarion SW1051 in 2.5 cubes w/ 4" port 8" long
Well I played around with port length and found a shorter port raised my tuning but gave me the upper bass which was totally lacking. I guess my question really is can you predict this from reading graphs? I gave up some extreme low end for now until I have more $ to upgrade the rest of the system. I guess I expected too much from my cheapo Clarions....
Was this due to designing box below free air resonance of the speaker?
Any opinions
Thx
Old 05-04-2009, 08:15 AM
nismos14's Avatar
Super Moderators
0/11 ssss18247
Feedback Score: 64 reviews
The peak in the lower end may give you the impression of a lack of upper end extension. Now adding a set of components that will play down to 60/80hz will give you the lacking upper end back.
Advantage of sealed, smoother response when in the right box.
My Car, My Ears.
Old 05-04-2009, 08:39 AM
Partially Unwound
0/11 sssss2697
Thats what I thought. I have always built boxes just using manufacturer recomended or someone elses design. When I simulated this box I didn't really believe the resulting output would match the response curve. Well it did so I was pleased but I am trying to understand the theory behind the loss of upper end. I am viewing it as a give and take type thing, like if I give low end extreme gain I have to get that gain from somewhere, and in this case it was upper end. Am I thinking about this correctly?
Components with stronger low end are on my list of upgrades. Hopefully soon...
Old 05-04-2009, 08:41 AM
nismos14's Avatar
Super Moderators
0/11 ssss18247
That makes sense, the other option is adjusting/adding an eq.
My Car, My Ears.
Old 05-04-2009, 09:14 AM
Partially Unwound
0/11 sssss2697
I wasn't sure if the EQ would work because on my HU the bass control centers at 50hz which I really didn't do anything (i run it flat) and there is a loudness at 100hz which would have been great but it also boosts treble which wasn't desired. I have a half din spot in my dash available, maybe I should look into EQ. I'm just not sure this would help, I am sure my best bet is upgrading to strong 6.5's in my doors first.
Old 05-04-2009, 09:17 AM
nismos14's Avatar
Super Moderators
0/11 ssss18247
Come up with a budget, I can help you out, and if you have any interest in Rainbow's I have a set available.
My Car, My Ears.
Old 05-04-2009, 09:51 AM
Partially Unwound
0/11 sssss2697
Its prob going to be piece by piece for now. I work in the auto industry on commission only and the car market is slow. I have a couple of side jobs coming up so I may be interested in the rainbows in the next couple of weeks. I will def let you know. Thx for your advice
Old 05-04-2009, 09:52 AM
nismos14's Avatar
Super Moderators
0/11 ssss18247
Anytime!
My Car, My Ears.
Have question, Need help! Bigboiii General Car Audio Discussion & Questions 13 03-22-2009 09:52 PM
I've got a question... again madmat Announcements - Suggestions - Feedback - Support 6 03-20-2009 11:54 AM
GIF question caps Technology & Computer 2 02-17-2009 09:44 PM
Radio Frequency response C3 Customs General Car Audio Discussion & Questions 13 02-09-2009 03:25 AM
DD Question worstenemy453 General Car Audio Discussion & Questions 30 01-12-2009 08:42 PM
