Quick question about solo 15" design - Car Audio Classifieds!
Old 09-06-2011, 02:16 AM
Racerkid15's Avatar
0/11 ssssss873
Default Quick question about solo 15" design
Building a box for my new AB XFL 15 I just picked up and right before I built it I was told the box would be too small but before that I was told it wasn't so I want some opinions.
The box is 4.8 Cu ft, (3.85 after port disp and approx 3.7 after sub disp.)
32 wide
18 depth
18 height
Was told for SQ use around 6-7 sq in of port per cube usually.. and for more SPL related use 12-16 sq in of port *per cube*
I ended up with 14.49 sq in of port per cube which I thought was perfect tuned @ 30.12 hrtz.
So does the XFL really need a bigger box? I've seen them sound good in as low as 2.5-3.0 and was told they should go in around 3-4 cu ft so 3.7 sounded good after the displacement.
Thanks in advance for the opinions.
2005 Dodge Magnum RT
4 Sundown Audio SA 15's, 1 Sundown SAZ4500 @ 0.5OHM Daily, 8 fosgate mids/highs w/ fosgate 400-4 amp. 152.9db @ 44 hrtz, 149.6db @ 22 hrtz sealed up legal on dash! Box 14.5 cu ft tuned @ 30 hrtz.
Old 09-06-2011, 03:59 AM
0/11 ssss31247
That box will do fine.
Old 09-06-2011, 12:28 PM
Racerkid15's Avatar
0/11 ssssss873
Awesome thanks man off to building!
Quick question: (1) JL W7 12" vs. (1) Sundown SA-15 papito General Car Audio Discussion & Questions 19 07-28-2011 08:10 AM
quick question need quick answer 05xxx perfect_prefect General Car Audio Discussion & Questions 0 01-25-2011 02:44 PM
comments/suggestions on my design for 18" Solo X jwesenick79 Enclosure Discussion & Design Construction Help 1 06-18-2010 09:28 AM
Quick question... Answer QUICK please its getting dark soon Sonically_Sound General Car Audio Discussion & Questions 11 10-03-2009 07:41 PM
quick box design question jmkanek General Car Audio Discussion & Questions 0 06-21-2009 09:23 PM
