loose panel help - Car Audio Classifieds!
Old 09-08-2011, 03:25 AM
0/11 ssssss288
Default loose panel help
The exterior baffle on my double baffled box apparently wasn't screwed enough or glued to the one under it at all. I'm about to start my first fiberglass project on a set of mids in my center console, could I just use resin between the baffles and then mat and resin around all exterior joints to ensure this doesn't happen again? Or resin and mat between the baffles, or just a garbage idea?
I have no wood glue and am incompetent enough that I don't want to screw into my box. I didn't build it for a reason. Using the fiberglass materials would be cheapest and easiest with all things considered IF it will actually be helpful. Any input appreciated.
For the record the baffle under the loose one seems to be entirely secure and intake so there should be no air leaks. Fiberglassing the exterior corners would just be a Better safe then sorry I think. But since already going to have the supplies out I'd like to use. Pretty isn't the concern here whatsoever BTW
In case it matters. Below is the box in question. Bottom baffle is screwed through the side panels every 6-8" but top only has a screw in each corner holding it to the bottom one.
Tapered t-line : TheBoxHouse, Enclosure designs
Need box help? Pm surreal
Old 09-08-2011, 03:13 PM
0/11 ssssss288
Going to work in 3 hours, stopping by Walmart when I'm off in middle of night to pick up my fiberglass supplies. A confirmed Yay or nay on my plan before I leave would be awesome if possible.
No smart phone, so once i leave the house I'm offline lol
Old 09-08-2011, 04:35 PM
0/11 sssss1811
Feedback Score: 63 reviews
Screws is your best bet. Will take fiberglass atleast a week to dry/harden enough to hold it to the strength you need it to all alone. If you aren't in a hurry to get the install going go for it!
V.
Old 09-08-2011, 04:47 PM
0/11 ssssss288
hrm. The install is already going, but just noticed this loose panel the other day. A week of down time may be doable vs conquering my fear of splitting wood and completely ruining the box.
Guess the decision comes when i found out how tiny my check is lol. Thank you very much, wasn't aware of the Week + cure time needed
Old 09-08-2011, 04:50 PM
tacomaguy1's Avatar
0/11 sssss4401
I'd squirt as much glue inbetween them as possible and use screws to clamp them back together
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
I need help guys! Im about to loose my cool with this thing! Raptor660 General Car Audio Discussion & Questions 17 04-15-2011 09:32 PM
My RE XXX 15 is very loose....... krunchbubble General Car Audio Discussion & Questions 16 05-08-2010 01:29 PM
At What Point Does A Sub Loose Linear Control BassikInstincts General Car Audio Discussion & Questions 52 12-12-2009 04:14 PM
might loose my lisence.. on bs terms snoopysnooper Uncensored Off Topic 18 10-19-2009 01:21 PM
let loose the dogs of war korey_hofer Off Topic Chat 6 09-15-2009 08:54 PM
