Port in middle of box - Car Audio Classifieds!
Old 09-10-2011, 01:53 AM
area51's Avatar
0/11 ssssss228
Default Port in middle of box
With the slot port in the middle of the box, between the two subs, how do you calculate port length when the port has to split between the two subs?
Old 09-10-2011, 02:13 AM
3rdshiftdiscretion's Avatar
CACO Late Night Crew
0/11 sssss4240
Feedback Score: 30 reviews
send me ure box dimensions as well as port width and height and what hz u want it at.
Bewbs
Old 09-10-2011, 02:24 AM
area51's Avatar
0/11 ssssss228
Pm sent, Thanks
Old 09-10-2011, 02:51 AM
0/11 sssss4240
full box with cutsheet sent via pm.
Bewbs
The Following User Says Thank You to 3rdshiftdiscretion For This Useful Post:
area51 (09-10-2011)
Old 09-10-2011, 04:11 AM
area51's Avatar
0/11 ssssss228
Thank you, thank you, thank you!
Old 09-10-2011, 04:15 AM
0/11 sssss4240
hope it sounds good. pretty simple build
Bewbs
Old 09-10-2011, 10:48 AM
0/11 ssssss542
Port tuning is not dependent on how many woofers.
I just did a port center and its working great so far.
Old 09-10-2011, 11:09 AM
DonH's Avatar
0/11 sssss6645
you take the total port length needed, run the port down the middle and leave it off the back wall half of the port width. so if the port is 4" leave it 2" from the back now split left and right. take the total port length subtract the amount from down the middle. whatever you have left divide by two and that will be the port length for the left and right side.
SHABAM
The Following User Says Thank You to DonH For This Useful Post:
area51 (09-10-2011)
Old 09-10-2011, 12:25 PM
area51's Avatar
0/11 ssssss228
Thank you for the explanation. That's kinda what I thought but just wasn't sure. This will be my first box with the port in the center so I'm trying to do it right the first time. But that'll never happen since I'll never be satisfied, lol.
aero port box for 4 sa-8's, too much port? Dbmonster (Sundown Audio) 4 08-11-2011 02:08 AM
shows and comps around Middle GA waresgaragestereo Competition Corner 0 09-10-2008 10:57 PM
