Enclosure for diamond HP 10? - Car Audio Classifieds!
Old 05-04-2009, 01:55 PM
0/11 ssssssss9
Default Enclosure for diamond HP 10?
I'm a total noob when it comes to how to build stuff and what dimensions mean and stuff so I need help designing a box in order to get the most out of my sub. It's a diamond HP 10". Their manual says that the optimum ported box should be 1.25 cubes w/ a 4x16.25" port. Then it has some other info that I don't understand, it says Fb/F3 (Hz)=42/33 and Pe(W) 800. Could someone please give me dimensions of the box I should make? Thanks a ton!
PS this is posted in the q's board as well, sorry for the double post
Old 05-04-2009, 02:11 PM
obrien202's Avatar
I race dertscooters
0/11 sssss4142
Feedback Score: 26 reviews
ygpm
may music always make you happy even if life does not
Enclosure for 2 15 XXX Silver-N-black Enclosure Discussion & Design Construction Help 10 04-28-2009 12:32 PM
Enclosure help for btl Team3d Enclosure Discussion & Design Construction Help 0 04-16-2009 08:45 PM
My First Enclosure Build s Beatz Build Logs 13 03-16-2009 10:01 AM
18" BTL enclosure aturcotte127317 Enclosure Discussion & Design Construction Help 4 01-10-2009 10:29 AM
Enclosure volume forceww Tutorials & Quick References 7 08-05-2008 01:53 PM
