10$ homemade circle jig - Car Audio Classifieds!
Old 09-13-2011, 10:41 PM
thumper21's Avatar
Blow-thru KING
0/11 sssss1919
Default 10$ homemade circle jig
Bought a $9.99 cutting board from Walmart. All I did was cut the cutting board to the width I wanted. Centered and traced the base-plate on the cut piece. Drilled the mounting screw holes and counter sunk them. Put my up-spiral bit in the router then mounted the new base (cutting board) to the router, made a small cut into the cutting board then measure from the outside edge of the hole to half of what size the cut-out is I'm needing. Keep in mind to keep the line for the measurements centered. I measured from the straight edge to the center of the bit and copied to the opposite end of the board. Then used a laser line to draw the line and mark my spots for 8-12" woofers. (Don't forget to drill out the center of the board for the router bits)
This is near exact for me as I was within a 1/32" of what cut-out I needed on each woofer. All you do is make your center point for the woofer, drill into the center point (not all the way through the wood), then detach the drill from the bit while its still in the wood and slide the new circle jig onto the drill bit. Be sure to use the same size drill bit that was used for the holes drilled on the router plate.
Speed and SQ
Old 09-13-2011, 10:46 PM
bigdhenderson's Avatar
0/11 sssss4981
Feedback Score: 45 reviews
I made something similar but with a thin piece of wood. Works pretty good. I had thought of the cutting board idea too but i found a thin piece of wood laying around.
I just make sure to measure to the outside of my bit when I do it. And I check before every cut and double check. So far its worked out pretty well
Old 09-13-2011, 10:47 PM
nicholask1993's Avatar
Dubstep Addict
0/11 sssss1802
I'm going to do something like this to make the adapters for my front 6.5 speakers.
1998 Subaru Forester
Sony CDX GT-565UP Head Unit
Cadence 6.5" Components
MB Quart Onyx 1500.1
/Surreal
Old 09-13-2011, 10:48 PM
thumper21's Avatar
Blow-thru KING
0/11 sssss1919
Yes sir.. It has worked tremendously well for me and I am quite a perfectionist when it comes to building my personal stuff.
Speed and SQ
Old 09-13-2011, 10:53 PM
0/11 sssss4519
I made one out of 3/8'' threaded rod. cuts from 8-21'' for less than 2 bucks
To find sealed resonance
resolve Vas/28.32 =
result of that +1
square root that result
Old 09-13-2011, 10:54 PM
thumper21's Avatar
Blow-thru KING
0/11 sssss1919
I refuse to use metal for my base plate.
Speed and SQ
Old 09-13-2011, 10:55 PM
thumper21's Avatar
Blow-thru KING
0/11 sssss1919
Hopefully your router has a small enough base. My routers base would only allow me to make a 8" cutout
Speed and SQ
Old 09-13-2011, 10:59 PM
0/11 sssss4519
Mine had holes from the factory for this purpose. and for a straight edge.
resolve Vas/28.32 =
result of that +1
toolmaker router circle jig? jackdaniels (Tool Maker) 677 06-09-2013 02:31 AM
need a router jig/ circle jig recomendations? marcotheclepto General Car Audio Discussion & Questions 14 09-09-2011 12:23 AM
FS: Router Circle Jig loudnlow931 Miscellaneous Stuff For Sale 5 03-17-2011 09:31 PM
Jasper Circle Jig teamsolo General Car Audio Discussion & Questions 31 03-05-2010 10:27 PM
[MODERATE] How To: Make Your Own Circle Jig danteBirosel Tutorials & Quick References 0 11-12-2008 02:25 PM
