Box for 2 T2D215s - Car Audio Classifieds!
Old 09-14-2011, 01:03 PM
lilteddyp's Avatar
0/11 ssssss403
Default Box for 2 T2D215s
Right now I have roughly this, and I say roughly because when lowes cut my wood, they ****ed up so this is now I remeasured what I have vs what I am supposed to have and came up with this. The port may be a little longer or shorter than what I have calculated as a result.
This is what I am thinking about doing.
The sound I am getting now is just too muddy, it's loud, just...I'm just not happy and I want it to be louder. Also with the subs up port back config right now, it is killing my hatch so subs up port up would be a better option for me.
I am currently running 1 T2500-1bd @ 2 ohms and with the new box I am going to want to run my other T2500-1bd so they will each be master/slave @ 4 ohms each.
All suggestions are welcome, I am on limited time to get something done because there is a show coming up on Sept. 25th in Lansing that I am "hosting" a "db drag" (not sanctioned, I will be using an SPL-LAB but it's better than the by ear bullshit they were gonna do, and it will be consistent because all cars involved will be using the same sensor)
Here is a flyer for the show if anyone in the area wants to come!
2001 Bravada (2wd) Pewter|JVC KW-AV60BT|Alpine Interiors|2 PSI/BTL 18's @ 32Hz|2 Rockford Fosgate T25001-bd's @ 4-ohm each|Rockford Fosgate T1000-4 on Mids|Rockford Fosgate T400-4|RF 3Sixty.2|Yellow Top up front 2 9a31s in back|LOTS of AT 1/0|Python 991|350a Singer Alt
Old 11-25-2011, 03:45 PM
0/11 sssss1406
the second would be much better but if i were you id buy new wood and cut it my self to get a larger box and tune it low and set your subsonic filter correctly to get rid of the mud. tune between 30 and 33
Dave the Box Guy Sub box for 2 15's 7'^3 @ 42hz for SUV 80$ OBO New England area hispls Wiring, Electrical & Other Installation Equipment 8 05-21-2011 01:43 AM
HAHA lightswitch box/ gang box completed mattintc10 General Car Audio Discussion & Questions 12 07-11-2010 07:00 PM
