Need Help From Experienced No Wall Box Builders - Car Audio Classifieds!
Old 09-18-2011, 08:36 AM
Bigpimpin91's Avatar
żoɹǝz ʎq pǝpıʌıp oɥʍ
0/11 sssss1149
Default Need Help From Experienced No Wall Box Builders
Experienced No Wall box builders:
I have 4Skar Audio VVX 12's in ~7 cubic feet on 3kw.
They move pretty damn close to XMECH with the current box.
What would you recommend in order for me to add my second AP 3000?
I know this isn't the most efficient box, and I resent that, but it's done everything I've asked of it.
Current box Specifications:
7 Cubes Net with Displacements +/- .2 cubic feet
8 4in PVC Ports 23in long
All 8 open = 39hz (~100 sqin of port)
Block off 4 for my daily tuning of 28hz
Team A**hole
'94 F250
12 Sundown Sa 10s
Crossfire 8k
0.33 Daily ftw.
Old 09-18-2011, 08:42 AM
ltr450racer690's Avatar
0/11 sssss3414
why not try less number of aeros, just bigger aeros.
AUDIOTECHIX DEALER
DLP CUSTOMS SALES REP
Old 09-18-2011, 08:46 AM
0/11 sssss1149
This has already crossed my mind.
Especially for numbers.
But, please explain how this will help the excursion issue?
Team A**hole
'94 F250
12 Sundown Sa 10s
Crossfire 8k
0.33 Daily ftw.
Old 09-18-2011, 08:49 AM
0/11 sssss3414
idk how much i would he the xmas prob. but def would help make the box more effiecent. then needing less power to do that
AUDIOTECHIX DEALER
Old 09-18-2011, 12:56 PM
surreal's Avatar
0/11 sssss2489
I would go with a bottom slot port box in my opinion.
Old 09-18-2011, 01:00 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
Where do the subs have crazy excursion? On the upper punch, or the low(bottom) end?
Old 09-18-2011, 01:13 PM
BKNIGHTS's Avatar
0/11 sssss2949
Feedback Score: 61 reviews
Turn the gain down, turn the volume down, make box smaller. You wanna give 1500watts to a 600watt sub
Old 09-19-2011, 02:08 PM
0/11 sssss1149
I planned on it, but this still doesn't help with the issue at hand.
It depends on what tuning, really.
At 28hz tuning, they move a **** ton @ 33hz and above.
They move less than half of that all the way down to 23hz.
This is America, we give everything too much of everything.
Team A**hole
'94 F250
12 Sundown Sa 10s
Crossfire 8k
0.33 Daily ftw.
Old 09-19-2011, 02:59 PM
Decaf's Avatar
0/11 sssss3460
Feedback Score: 24 reviews
Smaller box less port area using one larger diameter port
10" flared would work well
TeamGG
Team D.O.A.
Old 09-22-2011, 10:45 AM
0/11 sssss1149
Anymore input?
Team A**hole
'94 F250
12 Sundown Sa 10s
Crossfire 8k
0.33 Daily ftw.
Box Builders MopaRBumpiN Enclosure Discussion & Design Construction Help 1 05-06-2011 09:27 AM
Michigan Box builders!! WTB box for two 15's kowboy Wanting to Buy (WTB) 14 02-14-2011 06:49 AM
Experienced box builders question Boomintahoe Enclosure Discussion & Design Construction Help 7 10-15-2010 08:48 PM
box builders,help me! kingmade08 Enclosure Discussion & Design Construction Help 8 08-26-2010 12:40 AM
dd fans/box builders help!! brtnboarder3241 Enclosure Discussion & Design Construction Help 4 07-23-2009 12:15 PM
