Multiple slot ports - Car Audio Classifieds!
Old 09-18-2011, 09:02 PM
Matt3824's Avatar
0/11 sssss3754
Default Multiple slot ports
How do you use a tuning calculator when you want 2 seperate slot ports in the same enclosure?
Old 09-18-2011, 09:05 PM
0/11 ssssss270
i would figure you just add the 2 port areas together?
Old 09-18-2011, 11:50 PM
Are the ports the same size (surface area)? If so then Fox is right. For example:
(1) 10"x10" (100 in^2) port with a length of 20" is equal to
(2) 10"x5" (50 in^2) ports with a length each of 20"
How do you calculate length of center slot ports? taylorpro Enclosure Discussion & Design Construction Help 9 03-08-2011 04:08 AM
How do you calculate for two slot ports?? westman995 Enclosure Discussion & Design Construction Help 1 03-29-2010 04:21 PM
Calculating length for multiple tube ports white4d96 Enclosure Discussion & Design Construction Help 0 03-03-2010 07:58 PM
Help with slot ports and box design. omarquez510 Enclosure Discussion & Design Construction Help 0 02-13-2010 08:39 PM
Slot ports vs aero ports? 87linkin General Car Audio Discussion & Questions 6 01-16-2010 03:09 PM
