re audio sx 15 box help - Car Audio Classifieds!
Old 05-06-2009, 11:23 AM
0/11 ssssss111
Default re audio sx 15 box help
CAN SOME ONE HELP ME DESIGN A BOX FOR 2 15" RE SX SUBS in the trunk of a 1986 OLDS CUTLASS SUPREAM 2DR IM TRYIN TO put in the right box so it will be loud as hell make it feel like someone is hittin u in the chess with a big as hammer i want to port them through the rear deck so what i want to know is what kind of box should i use and what should it be tuned to for loud street bass thanks
Old 05-06-2009, 12:09 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
I can do it if you want but it's not free.
If your interested PM me the info listed below.
1) Car. Year, Make, Model:
2) Subs. Make, Model, Size, How many:
3) Power. How much power per sub:
4) Goal. SPL or SQ:
5) Box type Sealed, Ported, Bandpass, etc..:
6) Sub/port direction:
7) Max dimensions:
8) Desired NET vol and tuning(optional):
9) Finnishpaint, carpet, etc... :
10) Zip code for shipping Required for build only:
11) Additional comments:
I also offer sever options you can add if you would like. Please note these are options I offer and other builders may offer more or less options. If you want something you don't see listed feel free to ask.
Double baffle:
Double baffle/flush mount:
Round over all outside edges:
45's in all inside corners:
Kerfed port:
Kerfed walls:
Slanted back:
Paint inside of port:
/ CAAA Member #2 /
JL audio W7 10" in a JL Audio H.O box, JL audio 500/1v2 amp, stinger cap s10 with 4 15's Car Audio Packages 8 03-22-2009 01:50 AM
Re: O2 Audio (Oxygen Audio) 2500w amps xpl Recycle Bin 0 08-15-2008 11:23 PM
Re: O2 Audio (Oxygen Audio) 2500w amps forceww Recycle Bin 0 08-15-2008 11:17 PM
