45's in an aeroport - Car Audio Classifieds!
Old 09-22-2011, 11:47 AM
Team HKS
0/11 ssssss474
Default 45's in an aeroport
is there a way to do 45's in an aero port box and have it work for the good, or gain from it? i am using an 8 inch external aero and was doing decent numbers, just wanted to gain a little before finals.. so i 45'd the corners and lost a whole db.. is there any way i can fix this and be louder than with no 45 at all? or is there any other little thing i can do to add the same effect? (just need a few tenths)
Old 09-22-2011, 11:53 AM
98GMC's Avatar
0/11 sssss1265
Remove the 45's and cut some pvc in half and try to direct the air flow directly towards the port with the rounded pvc. May or may not work. Did you round over the edges on the outside of your enclsoure?
Old 09-22-2011, 11:59 AM
Team HKS
0/11 ssssss474
never even thought of pvc... that will definitely be my next approach. and yea everything's rounded and smooth.
Old 09-22-2011, 12:02 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
45's in the WRONG corners can hurt. usually, say if you have your ports along the bottom in a sub up/port back setup, you could run a 45 horizontally along the bottom and see a gain. some have made a little triangle like you would on a center slot box to help air in the direction of the port. really id just test a bunch of diff combos. its different for every situation really
-Youtube Channel
Old 09-22-2011, 12:07 PM
Team HKS
0/11 ssssss474
bummer thats what i was afraid of, some of them could have helped me, or maybe only one is killing me. i knew it was a box specific problem and there isn't like one perfect answer, just looking for suggestions to try while im doing a weekend of testing.
thanks for the reply!!
Displacment of 45's AQsrt4 Enclosure Discussion & Design Construction Help 3 05-09-2011 04:43 PM
[FOUND]WTB Some 45's taylorpro Wanting to Buy (WTB) 5 03-16-2011 08:56 PM
45's in my box? mcintosh at asylum Build Logs 30 12-07-2010 06:40 AM
Some questions about 45's Dbmonster General Car Audio Discussion & Questions 2 09-07-2010 02:06 PM
45's in the corners in a box Patrick Simmons Enclosure Discussion & Design Construction Help 14 07-18-2009 12:53 AM
