port question - Car Audio Classifieds!
Old 09-25-2011, 12:15 PM
kush killer's Avatar
0/11 ssssss152
Default port question
ok i have a 01 gmc sierra ext cab.. doing 4 sa8's under rear seat.. now my box is 56 wide which leaves me approx 3-4" on each side of the box, right now its ported with 2 4" areos . 1 out each side of the box. now my questions is.. would it be better to run ports in location so box would be subs front ports side.. or move the ports to the front, use a 90 elbow , to achive a longr port length.. enclousre is ruffly 2.2 cubes after displacments right now i have full length psp flared aeros, belive that to be about a 36-38hz tune.. id like to get it a tad lower if possible and gain as much output at spossible
reason being i ask about moving ports also is that the hump in my box for hump in floor is also about 2-3" s away from the port opening.. was think its possibly being choked
Old 09-25-2011, 12:20 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
well since the ports are basically facing each other that may cause issues as well. try to plug one port and see what it does. a single 4" port wont be ideal IMO, but its not bad. it'll lower tuning a ton too so you can tell if you like it more. do you have room to put both aeros on one side? or maybe use a 6" port on one side instead of the two 4's?
-Youtube Channel
Old 09-25-2011, 12:26 PM
0/11 ssssss152
well i wondered about that too.. the designer said is should have any porblems but.... i also thought baout possibly do a sqaure or rectangle "T" shaped port out the front? onylt hing is i dont think i d have enuff room to achiave port area
Old 09-25-2011, 12:27 PM
0/11 ssssss152
also a 6" wont fit on the sides , i know theres been several biulds like mine but i can seem to get any info on enclosure
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
those under seat boxes are a pain at times. try this, inside the box, try to glue a little divider against the back wall. that way you cant see clear the the ports ya no? it may help each port work better seeing as there is something solid behind it to direct air; not just another open tube. its worth a shit ya no?
-Youtube Channel
Old 09-25-2011, 12:28 PM
0/11 ssssss152
i showed my design to "ram designs" he seem to think i should leave it the way it is.. but i always liek to get input from more than one source
Old 09-25-2011, 12:29 PM
0/11 ssssss152
yeah thats acutally not to bad of a idea
ill even tapper the edge to nothing
Old 09-25-2011, 12:31 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
its an idea. or maybe, if you wouldnt lose too much displacement, just split the box into two different chambers. like the 2 subs on the left and the left aero, and the 2 subs on the right and the right aero. you'll lose alittle displacement, but it may fair better. just re-run the numbers and see what ya get
-Youtube Channel
Old 09-25-2011, 01:02 PM
0/11 ssssss152
desicions desicons
Old 09-25-2011, 01:04 PM
0/11 ssssss152
ok lemme ask ya this.. say i divide it, do youthink i should 45 agaisnt the "new" wall or??
port question for OA 15 arntsmag General Car Audio Discussion & Questions 26 11-21-2010 06:46 PM
port question ? extremechevyman67 Enclosure Discussion & Design Construction Help 87 09-23-2010 06:30 PM
Port question Wisneaky General Car Audio Discussion & Questions 2 08-30-2010 04:17 PM
L port question dylan9999 General Car Audio Discussion & Questions 41 08-22-2010 12:01 AM
port/sub question RidnClean Enclosure Discussion & Design Construction Help 2 03-06-2009 04:09 PM
