carbon question - Car Audio Classifieds!
Old 02-08-2012, 12:48 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
Default carbon question
i love the write-up you guys did on recones.
Drop-in Recone kit - Assembly Instructions
however there is no mention of carbon fiber cones or dustcaps. i was told that ca glue doesn't adhere well to carbon fiber. what adhesive do you you when installing a carbon cap onto a carbon cone and still look good?
i have heard wonder goop will work but......
My game is legit,
Old 02-08-2012, 01:31 AM
Prohibited Sellers/Buyers
0/11 sssss1326
a good quality 2 part epoxy should do the trick
Old 02-08-2012, 10:37 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
ok,but wouldn't that be a pain to take off when time to recone if you plan on reusing the carbon cone and cap?
My game is legit,
Old 02-08-2012, 09:35 PM
Quite Northern Michigan
0/11 sssss1309
Goop should be fine. I think David told me its perfectly fine for dust caps.
Remember, the pain inside can't be fixed by something outside, all you can do is cover it up that way. It's totally an inside job.
Everything in life is a test. You always come out stronger on the other side.
Old 02-09-2012, 04:22 PM
0/11 ssssss345
I use E-6000. It's from the same Goop company but thinner and a little easier to work with.
Old 02-09-2012, 04:32 PM
0/11 sssss1326
yes both e6000 and goop will work as well as be a removable solution. if thats the goal.
Old 02-09-2012, 08:20 PM
TeamPSI's Avatar
0/11 sssss4041
http://www.caraudioclassifieds.org/forum/fix-my-speaker/111203-drop-recone-kit-assembly-instructions.html
Depending on the actual cone and dustcap themselves, I may use CA, rubber adhesive, or a layer of both to be honest.
Our CF caps stick to both of our adhesives, and very well!!
-David Moore
Old 02-09-2012, 08:31 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
it was a dd 6" carbon cap(trimmed it to fit edge of surround to edge of surround),not sure brand of carbon cone. using psi black ca and accelerator.
My game is legit,
Old 02-09-2012, 09:04 PM
TeamPSI's Avatar
0/11 sssss4041
That should hold it!
-David Moore
Carbon Fiber Cone Project UPDATE PG 11 Carbon Kelvar Caps!! RustyWCA (DC) 185 12-05-2011 03:30 PM
Anyone need Carbon Fiber? terra General Car Audio Discussion & Questions 25 11-28-2010 03:59 PM
carbon fiber ar-15 korey_hofer Sports and Fitness 3 11-25-2010 06:39 PM
Carbon cone MR.T3 General Car Audio Discussion & Questions 52 12-12-2009 07:33 PM
new DD carbon caps bones22 Off Topic Chat 40 07-08-2009 12:45 AM
