Recone for TREO CSX 12in - Car Audio Classifieds!
Old 03-16-2012, 10:55 AM
schrummy's Avatar
0/11 ssssss288
Default Recone for TREO CSX 12in
Woofer Brand: TREO Engineering
Impedance (Per voice coil): 1.5 -1.7
Model: CSX
Photo:
We need to know:
How much power does EACH subwoofer need to handle? SPL only
What impedance will you need (Per voice coil)? 1.5-1.7
The brand AND model of amplifier you'll use with it? (2) TREO CXT 4.1i
The type AND size of enclosure that it needs to work in? (Sealed, ported? Tuning Frequency?) NA
The type of music that you'll listen to with it? Tone only
Will you be competing with it, or is it a daily usage subwoofer? Comp only
Is it for competitions only? yes
Would you like any special colors? If so, where? pink cone with black dust cap, and if you want a pink PSI decal..... something along those lines.... if its not too much
Upgrades of any sort? Direct leads, carbon fiber dustcap, etc? Direct Leads
If you have a budget to keep, what is it? If you can keep it under $150 each... that would be awesome but what ever it needs to be, i will pay (stabbed the subs so, cant turn back now)
Where are you located? Ames Iowa 50014
Any other special instructions or requests? Would like to get this moving as soon as possible. I have shows coming up and i dont want to kill my SA-8.... only other sub that i have that works.... lol
150 db @ 33hz
Team Midwest
Old 03-17-2012, 07:15 PM
TeamPSI's Avatar
0/11 sssss4041
What we need from you are photos and measurements from the motor of the subwoofer. Please refer to the .pdf located at http://www.fixmyspeaker.com/pdf/MeasurementListB.pdf for reference.
-David Moore
The Following User Says Thank You to TeamPSI For This Useful Post:
sthrnbumpn (03-17-2012)
Old 03-25-2012, 12:47 AM
schrummy's Avatar
0/11 ssssss288
1. Pole OD = 3.0010
2. Top Plate ID = 3.2565
3. Magnet Diameter = 8 3/4
4. Spider Landing = 8 1/8
5. Spider Landing to Surround Landing = 1.8760
6. Top Plate to Spider Landing = 1.281
7. Top Plate Height = 1.2555
8. Magnet Height = 2.014
9. Coil Length = 1.5215
10. Coil ID = 3.0205
11. Coil OD = 3.1575
all measurements are in inches
pics in a bit
let me know
150 db @ 33hz
Team Midwest
The Following User Says Thank You to schrummy For This Useful Post:
TeamPSI (04-04-2012)
Old 03-25-2012, 12:59 AM
schrummy's Avatar
0/11 ssssss288
let me know if something dosnt make sense......... also the dime is 11/16 inches...
150 db @ 33hz
Team Midwest
Old 03-26-2012, 09:02 PM
schrummy's Avatar
0/11 ssssss288
bump for new measurements
150 db @ 33hz
Team Midwest
Old 03-28-2012, 10:12 AM
schrummy's Avatar
0/11 ssssss288
bump for new info
150 db @ 33hz
Team Midwest
Old 04-04-2012, 01:04 AM
TeamPSI's Avatar
0/11 sssss4041
YGPM!
-David Moore
Old 04-04-2012, 05:29 PM
schrummy's Avatar
0/11 ssssss288
you have a reply sir
150 db @ 33hz
Team Midwest
Old 04-16-2012, 06:39 PM
schrummy's Avatar
0/11 ssssss288
updates
150 db @ 33hz
Team Midwest
Old 06-10-2012, 12:06 AM
schrummy's Avatar
0/11 ssssss288
going to be needing recones again.... the dual spider isnt liking 33hz with 4k going to it....
150 db @ 33hz
Team Midwest
FS or Trade (2) TREO CXT/CSX 12in dual 4 schrummy 12" Subwoofers 31 02-23-2012 02:04 PM
treo csx 18 97T5WAGON 18" Subwoofers 7 11-19-2011 07:19 PM
treo csx 15'' recone eddiemoua94 (Fix My Speaker) 1 08-16-2011 06:38 PM
Treo CSX recone kr-15 (Fix My Speaker) 0 08-13-2011 12:38 PM
Quote Recone Treo CSX Biggy (Fix My Speaker) 8 02-08-2010 01:01 PM
