1995 Tahoe 2DR 4WD Lifted 4.56's Flowmaster 37's 20's - Wrecked but running! - Car Audio Classifieds!
Old 05-01-2012, 08:48 PM
TeamPSI's Avatar
0/11 sssss4041
Default 1995 Tahoe 2DR 4WD Lifted 4.56's Flowmaster 37's 20's - Wrecked but running!
Up for sale is my prized possession for many years. My 1995 2 door Chevy Tahoe 2 door.
In March 2012, we planned to take it to Tampa Florida to be dropped off for a complete interior rebuild, huge sound system, new door panels, carpet, the works basically. To make the trip from Memphis to Tampa, we changed every part needed to make the truck 100% trip worthy. We also stripped the interior, and had all of the plastics in the rear of the truck.
The truck needed axle shafts, rear brakes, windshield wiper motor, AC compressor, full tune up, oil change, etc. We worked for a week solid (at least)making sure that we had it all taken care of. We finished the night before leaving out for Tampa.
Well.... I used my trusty impact gun to install the wheels that night, which had served me well for 5+ years. Evidentially, the wheel was in a bind when tightening the lug nuts, because as we were driving down the highway roughly 125 miles from home... The rear driver's wheel came off!!
We were pulling a truck and trailer behind us, so when the wheel came off, all hell broke loose. We flipped the Tahoe twice, threw the other truck from the trailer, and landed right side up, just off the highway, with the engine still running! :-O
I have worked on this truck for many many many nights, and hate to see her go, but I can't see myself rebuilding it, or building another truck from these parts. I am sure that there is someone out there with a stock OBS truck who would love to grab all of the parts that they needed in one swoop... so here they are!
-David Moore
Old 05-01-2012, 08:49 PM
TeamPSI's Avatar
0/11 sssss4041
There is a bent upper A-arm and tie rod on the front Driver's wheel, from where the front end landed in the crash. The upper relocating bracket was also slightly bent, but could easily be repaired. This was the only part of the suspension or drive train that was damaged in the accident other than the upper ball joint, which has already been replaced. You can see how the front wheel sits at an angle in this photo...
The truck was in perfect running condition when we wrecked it. I had just spent ~$2000 the previous week to overhaul the truck and get it worthy of a trip from Memphis to Tampa, FL and back.
I guarantee that the engine, transmission, transfer case, and axles all function properly. The only thing keeping the truck from driving down the road are the bent suspension components on the front Driver's wheel.
The doors, fenders, hood, etc are all good.
The rear of the truck is bent over, and would have to be completely cut off and replaced to be repaired.
The door glasses are both good.
The fender flares are all good except for the rear passenger side.
The entire interior is gutted, but all of the pieces are inside of the truck, The dash is no good, but the rest of the parts are all still good.
One wheel (the one that came off) has some damage to where the lug nuts go, but the lugs DO tighten the wheel down very well. I would trust it to drive on, but it could be filled and drilled if you wanted.
The AC system was just rebuilt, and is full of Freon. It blows ICE COLD!
Drivetrain:
350 TBI, stock with ~150k (Runs PERFECTLY)
4L60E stock transmission
Aftermarket parts list:
20" KMC Hot Wheels series wheels
37" x 13.50 x 20" Nitto Mud Grapplers (~40% tread)
Pro Comp 6" suspension lift
3" Summit body lift
4.56 Yukon gears front and rear
14 bolt semi floating rear axle from 2wd 1500HD (open)
Stainless steel front brake lines
Flowmaster 10 series muffler
High flow catalytic converter
Westin black tube steps
(4) Kicker RS65 6.5" component sets (installed in front door panels)
Class 5 hitch
Dual bright light wiring relay mod
Radiator from HD series trucks
BRAND NEW parts installed less than 150 miles before the accident:
AC compressor (w/ warranty from Autozone)
AC Drier (w/ warranty from Autozone)
AC O-rings
Windshield wiper motor (w/ warranty from Autozone)
Windshield wiper blades
Upper ball joints (w/ warranty from Autozone)
Drag link (w/ warranty from Autozone)
Pitman arm (w/ warranty from Autozone)
Rear end outer seals (w/ warranty from Autozone)
Rear end gear oil
PCV valve
Valve cover gaskets
Distributor Cap (w/ warranty from Autozone)
Rotor button (w/ warranty from Autozone)
Bosch Premium spark plug wires (w/ warranty from Autozone)
Autolite 26 spark plugs (w/ warranty from Autozone)
Fresh oil change (Rotella-T 15-40 and Fram filter)
Blinker and marker bulbs
Percy's dead soft aluminum header gaskets (sealed up tight!)
Extra parts that are all included with the truck, but not installed:
14 bolt SF axle from 4WD truck
14 bolt SF axle from 2WD truck
Stock front 4WD differential
OEM fit, shorty headers (leaked so I removed)
Pair of Edelbrock front shocks (used)
GM Performance Parts TBI intake
TBI spacer
Also included are two mostly complete engine parts sets!!
Engine 1:
This was the original engine from this truck. After doing some work to the heater core, I forgot to replace the antifreeze, and the block cracked!!! The engine was still running perfectly the day that I removed it and tore it down. The entire engine is included, minus the block itself! You'll get the crank, rods, pistons, heads, intake, throttle body, brackets, etc... If you have a 1995 block to use, these parts would last another hundred thousand easily!! There is no damage to the components of this engine.
Engine 2:
Pre 87 360 block, 0.060 over. Has stock rods, forged pistons, good stock crank, and more misc parts.
-David Moore
TeamPSI's Avatar
0/11 sssss4041
Pics of the stuff!
-David Moore
TeamPSI's Avatar
0/11 sssss4041
I have owned this truck since 2006. I bought it from the original owner with 125,000 miles on it.
The truck started its life with me 100% bone stock. It slowly grew from a 3" body lift, to a 4" lift, to a 6" lift with the 3" body lift. Here are some pics of it as it grew...
Here is the truck as it looked before we crashed!
The price for everything is $2500 cash. I am not currently interested in separating any parts at all, and I will not take less than the asking price.
Someone could either use this truck as the ultimate parts donor vehicle, sell it for parts and make a couple of thousand dollars, repair the A-arm, chop the top, and wheel the crap out of it, or even just do a body swap and have a quick lifted truck!
The truck is located near Senatobia MS. Bring a trailer and the Tahoe will drive right on it!
If you are interested in the truck EMAIL ME at
TeamPSI @ Gmail dotcom
-David Moore
Old 05-01-2012, 09:07 PM
0/11 sssss1053
how much for the ecm ? pm me a price and your number.. i need for my 95 suburban k1500 4wd tbi.. thanks.
[SIGPIC] 4 15'' modded juggernauts with aluminum voice coils.. juggernauts will do 4000 rms per sub...and im swapping my 2 kicker 2500.1 amps, for a stetsom 10kd.. the rest of my system is ... 2 kicker 650.4 amps, 4 10'' evm dl10x mids. 4 8'' beyma highs. kicker kx3 3 way crossover, alpine old school digital sound field processor, over 100 feet of 0 awg flex wire and 300 amp iraggi alt, 4 deka intimidator batts...
Old 05-01-2012, 09:08 PM
FatBoy2's Avatar
That was crafty.
0/11 sssss1790
Fo eights in da pickup!
The Following User Says Thank You to FatBoy2 For This Useful Post:
TeamPSI (05-01-2012)
1995 2 door tahoe speaker sizes CarAudioFanatic General Car Audio Discussion & Questions 4 10-13-2011 02:28 PM
1995 4 dr. Tahoe with 15in Ma Audio maxdout918 Enclosure Discussion & Design Construction Help 2 09-05-2011 01:58 AM
4wd HI????? SacTownBully84 General Automotive Chat 11 02-18-2011 11:37 AM
Brian actually wrecked the z F3M4 Off Topic Chat 115 11-19-2010 10:30 AM
think its my amp or sub thats wrecked? dylan9999 General Car Audio Discussion & Questions 2 05-18-2010 01:08 PM
