Eclipse tc9 motor recones - Car Audio Classifieds!
Old 06-12-2012, 10:10 PM
Buddah_iii's Avatar
0/11 ssssss302
Default Eclipse tc9 motor recones
curious if you guys carried parts for these. and if you know which baskets will mount to these i know its a crapshoot on the 2nd questions but i appreciate your time thanks
absolutely there build so damn stout/air tight a gnat could fart a 50
Old 06-16-2012, 12:40 PM
TeamPSI's Avatar
0/11 sssss4041
We carry tons of parts to fit those motors. They are probably the most universal subwoofer motor on the planet. Great to use for rebuilding.
As long as you have a 6 bolt pattern on the top of the motor (5" apart), then you'll have a ton of choices, as most common subs use this same pattern.
In order to get you and to get you the correct parts and pricing to build your subwoofer, we need to get a little more info from you.
We need to know:
How many do you have?
What size does it need to be?
How much power does EACH subwoofer need to handle? (RMS power)
The brand AND model of amplifier you'll use with it?
The type AND size of enclosure that it needs to work in? (Sealed, ported? Tuning Frequency?)
Is it for competitions only?
Where are you located?
Please send photos of the actual subwoofer or motor so that we can verify the exact parts spacing.
If you have any questions, just let us know.
Thanks,
FixMySpeaker
-David Moore
Recones for Eclipse Audio 88120 Masterofallbass (Fix My Speaker) 1 01-16-2012 06:49 PM
FS: eclipse tc9 15 - 99$ Bushj311 15" Subwoofers 18 08-11-2011 09:11 PM
WTT: 4" coil sub, tc9 eclipse sub autotek mm2k Bushj311 Car Audio Trader (WTT) 15 06-21-2011 03:28 PM
TC9/Eclipse Motor Lax916 Speaker Accessories & Parts 9 11-03-2010 07:57 AM
[SOLD] F/S:: Orion HCCA motor & Basket (TC9+ motor) bangin_explorer 15" Subwoofers 9 03-05-2009 10:41 PM
