2-nightshade v1 12s - Car Audio Classifieds!
Old 06-15-2012, 10:12 PM
KEVGNAR's Avatar
0/11 ssssss928
Default 2-nightshade v1 12s
i need two 12in nsv1 kits that will handle about 2k each with like 3- medium spiders, pm me!!
Even though this is definitely not built for numbers, demos speak a thousand words...
1990 Oldsmobile Cutlass Cruiser
Old 06-16-2012, 11:48 AM
TeamPSI's Avatar
0/11 sssss4041
In order to get you and to get you the correct parts and pricing to build your subwoofer, we need to get a little more info from you.
We need to know:
The brand AND model of amplifier you'll use with it?
The type AND size of enclosure that it needs to work in? (Sealed, ported? Tuning Frequency?)
Is it for competitions only?
Where are you located?
Please send photos of the actual subwoofer so that we can verify the exact motor, frame, and parts spacing.
If you have any questions, just let us know.
Thanks,
FixMySpeaker
-David Moore
Old 06-16-2012, 01:35 PM
KEVGNAR's Avatar
0/11 ssssss928
What impedance will you need (Per voice coil)? 1.4
The brand AND model of amplifier you'll use with it? two skar1500.1s
The type AND size of enclosure that it needs to work in? (Sealed, ported? Tuning Frequency?)a 3:1 4th with each driver @1.6cu
The type of music that you'll listen to with it? lows, would like to rape them
Will you be competing with it, or is it a daily usage subwoofer? bit of both more daily
Is it for competitions only? nage
Would you like any special colors? If so, where? nage
Upgrades of any sort? Direct leads, carbon fiber dustcap, etc? would like 2-3ft 8ga leads
If you have a budget to keep, what is it? yes, i cook deliver pizzas so the funds for them will be limited
Where are you located? 54864
stitched surround and 8 LAYER FLATWOUND COIL
Please send photos of the actual subwoofer so that we can verify the exact motor, frame, and parts spacing.-----i would like to build the kit myself, so i need CA GLUE and shims
Old 06-16-2012, 03:04 PM
TeamPSI's Avatar
0/11 sssss4041
YGPM...
-David Moore
two nightshade 12s makeing a new sunroof strongarm25d Car Audio Videos 5 01-26-2012 01:24 PM
Audioque hdc3 12s or MTX 9500 12s??? 1993burban General Car Audio Discussion & Questions 18 12-08-2011 12:56 AM
Sundown Nightshade 12s GA_GT1 Wanting to Buy (WTB) 0 10-02-2011 06:05 PM
6th Order for 2 Nightshade 12s tprice07 Enclosure Discussion & Design Construction Help 2 07-30-2011 12:04 PM
[GONE]Nightshade 18'' and AudioQue 2200 -- Looking for 12s, 10, and 8s Bobby32 Car Audio Trader (WTT) 36 06-07-2010 11:34 PM
