recone for lvl4 m1 18 - Car Audio Classifieds!
Old 06-26-2012, 03:39 PM
0/11 ssssss443
Default recone for lvl4 m1 18
i bought a previously reconed 18 from another member on here (I believe done himself or at local shop.) the sub sounds to have terrible coil rub so i need to get it reconed i would like it done the same as before.
the previous recone was dual 2ohm done up with triple spiders and dual leads.
Woofer Brand: DC
Impedance (Per voice coil): dual 1ohm
Model: lvl4 m1
Photo: don't have
(RMS power) 2-2.5krms after rise more than likely
What impedance will you need (Per voice coil) Dual 1ohm
The brand AND model of amplifier you'll use with it? crescendo bc2k
The type AND size of enclosure that it needs to work in? will be building a 4th order 3:1 ratio tuned between 44-46hz
The type of music that you'll listen to with it? should work well with all frequencies of music being in a 4th..
Will you be competing with it, or is it a daily usage subwoofer? daily usage
Upgrades of any sort? Direct leads, carbon fiber dustcap, etc? I would like to keep the same upgrades as what is on it currently just switch it to dual 1ohm
Where are you located? LA 20 minutes north of new orleans
Old 06-30-2012, 08:46 PM
TeamPSI's Avatar
0/11 sssss4041
YGPM!
-David Moore
[SOLD]fs: two dc lvl4 xl d1's fresh recone! Zooook 12" Subwoofers 42 09-02-2010 11:42 PM
New lvl4 xl _s_m_a_c_ (DC) 21 05-21-2010 10:55 PM
Need some help with lvl4 xl JusRsounds (DC) 8 04-20-2010 10:24 AM
DC lvl4 recone?? RetroAudioInc (DC) 9 09-21-2009 09:30 PM
