Re-cone for OS Round Kicker Solobaric S15-4 x 4 - Car Audio Classifieds!
Old 08-14-2012, 07:02 PM
0/11 sssssss21
Default Re-cone for OS Round Kicker Solobaric S15-4 x 4
I have four (4) Kicker Solobaric S15-4 from 1999 or so. They are round, with the black and red poly cones. Three of them work fine; beat up, but still servicable. The other has had a 6V battery stored on its cone for a number of years. The suspension is collapsed in that sub and the VC hangs almost all the way into the motor.
I love these subs, the small box they play in, and the fact that I already have them. I want to use them on a pair of Zed Audio Hifonics Zeus (Gen VIII) that Mr. Mantz is restoring now. These subs come with a single 4 ohm coil and were designed to play in small sealed enclosures. They accomplished this by having a very massive cone, high excursion, and a relatively loose suspension.
My question is this: Would it be possible to recone these subs, first and foremost. If so, could the original intent of the subs (heavy cone loose suspension) be incorporated into the recone solution. I feel like Im asking too much, but would a longer/stouter coil be of use?
I plan to run these in a 4th order enclosure of a Crown Vic, vented into the cabin.
Old 08-21-2012, 10:29 AM
TeamPSI's Avatar
0/11 sssss4041
To be honest with you, we will not have suitable parts for those. Our surrounds and spiders are all much stiffer than what you would have had (and need) for those subwoofers.
In reality our cones are probably much heavier as well.
Our spiders and surrounds would actually allow for too much excursion to work properly with those motors or frames, even with a stock sized voice coil.
I would honestly recommend contacting these guys - "Credence Speakers"
-David Moore
Old 08-21-2012, 08:59 PM
0/11 sssssss21
Ok, I figured as much.
However, I also have a pair of 15s that need to be reconed. The motors have 2.5 inch (i.d.) coils, double stacked magnets, and a bumped pole peice. The frames are aluminum and have 8.5 inch spider landings.
I would like a d4 coil with flat windings. I would be very interested in any composite cone/dustcap material available, but a good heavy pulp-based cone should be fine. Tinsel leads should be woven or at least tied down, but I will defer to your judgment and experience for the rest.
Is their a phone number or email where I can contact PSI directly?
Old 08-21-2012, 09:53 PM
TeamPSI's Avatar
0/11 sssss4041
[email protected]
-David Moore
New 10" Round Kicker Solobaric Subwoofer s10c just1n 10" Subwoofers 9 07-07-2012 03:42 PM
round kicker solobaric shriver187 General Car Audio Discussion & Questions 1 09-26-2011 12:04 PM
Round Solobaric By PSI david in germany (Fix My Speaker) 13 05-01-2010 05:00 AM
