Incriminator Lethal Injections - Car Audio Classifieds!
Old 10-21-2012, 04:02 PM
whos that's Avatar
0/11 sssss1635
Default Incriminator Lethal Injections
Woofer Brand: Incriminator audio
Impedance (Per voice coil): 1
Model: Lethal Injection
How much power does EACH subwoofer need to handle? (RMS power) Around 750-800
What impedance will you need (Per voice coil)? 1
The brand AND model of amplifier you'll use with it? Old AQ3500
The type AND size of enclosure that it needs to work in? (Sealed, ported? Tuning Frequency?) Ported, roughly 1.75 net/per sub, tuned 32-34
The type of music that you'll listen to with it? Decaf, mostly 28-35 hz
Will you be competing with it, or is it a daily usage subwoofer? daily
Is it for competitions only? no
Upgrades of any sort? Direct leads, carbon fiber dustcap, etc? I need direct leads, would prefer incriminator dust caps if possible, otherwise green dust caps will do
If you have a budget to keep, what is it? Would like to be between 100-150 per woofer if possible
Where are you located? Northern Illinois
Any other special instructions or requests? If you can do anything to make the triple joints stronger, that would be nice. I just had one of them start to come apart on me.
Old 10-25-2012, 09:14 AM
whos that's Avatar
0/11 sssss1635
Bump...
Old 10-28-2012, 12:38 PM
whos that's Avatar
0/11 sssss1635
Ordering my recones from incriminator now, thanks for the help.
Incriminator Audio Lethal Injections 12s D4 turkishvalo 12" Subwoofers 34 11-15-2012 05:42 PM
2 12'' Incriminator Audio Lethal Injections D4 AndrewBR98 12" Subwoofers 15 02-18-2012 07:36 PM
4 Incriminator Audio Lethal Injections jfoodstamp 15" Subwoofers 44 12-13-2011 09:07 AM
box for lethal injections help please !! 00ram360 Enclosure Discussion & Design Construction Help 3 06-06-2011 10:16 PM
2 12" Incriminator Lethal Injections D4 06GTMIKE 12" Subwoofers 43 01-25-2011 02:24 PM
