04-05 XXX coil - Car Audio Classifieds!
Old 10-30-2012, 08:18 AM
bshizzle88's Avatar
0/11 sssssss64
Default 04-05 XXX coil
Can I buy just the Former/Coil with spiders/leads? Is it better to use the same style spiders it has or would linear be better for this? I'd like for it to be a bit stronger and louder than the factory parts. I wont mind if I gain some FS and lose some SQ..
Eclipse CD8445 + 5083
RE XXX v3 12 in 2.25 net @ 30
TQ1601d (temp)
Knu Flex 1/0
Old 10-31-2012, 09:04 PM
TeamPSI's Avatar
0/11 sssss4041
We can definitely sell you the coil and spiders!
We can use a stiffer spider setup on them. We'd use a progressive spider, just stiffer.
-David Moore
Old 11-01-2012, 05:38 AM
bshizzle88's Avatar
0/11 sssssss64
Cool! I saw somewhere you said it raises the Fs a few right ? Will this make it a touch louder?
TQ1601d (temp)
Knu Flex 1/0
Old 11-01-2012, 08:16 PM
TeamPSI's Avatar
0/11 sssss4041
Stiffening it will automatically raise the Fs. It wont be by very much... maybe 3-4hz tops.
If the box is in line to peak higher than 35hz, then yes, it would probably be a little louder overall.
-David Moore
FS/T - xxx / tsns bigggg 4" coil motors !! __d_a_v_i_d__ Speaker Accessories & Parts 17 10-29-2011 01:33 AM
SS XXX coil 1ndatrunk Speaker Accessories & Parts 4 06-14-2010 09:28 PM
SS xxx 15 replacement coil kranksta (Fix My Speaker) 2 03-30-2010 07:10 PM
XXX coil question terra General Car Audio Discussion & Questions 19 06-11-2009 11:51 PM
RE XXX 06+ Split Coil Design RE_XXX General Car Audio Discussion & Questions 6 05-26-2009 02:41 PM
