Dave is going to need the below info, is this a 04/05 motor?
Woofer Brand:
Impedance (Per voice coil):
Size:
Model:
Photo:
In order to get you and to get you the correct parts and pricing to build your subwoofer, we need to get a little more info from you.
We need to know:
How much power does EACH subwoofer need to handle? (RMS power)
The brand AND model of amplifier you'll use with it?
The type AND size of enclosure that it needs to work in? (Sealed, ported? Tuning Frequency?)
Is it for competitions only?
Where are you located?
If you have any questions, just let us know.
