Recone for 2 - 12in treo ssx duel 2ohm - Car Audio Classifieds!
Old 01-23-2013, 07:22 PM
Brand New Members
0/11 ssssssss3
Cool Recone for 2 - 12in treo ssx duel 2ohm
Woofer Brand: Treo Engineering
Model: ssx duel 2ohm
Do you have more than one of these subwoofers used in the same installation? If so, how many? 2
How much power does the/each subwoofer need to handle? (RMS power) 2000 watts rms each
What impedance will you need (Per voice coil)? duel 2ohm
The brand, model, and quantity of amplifiers that you'll use? (1) atomic at3000.1d
The impedance at which you plan to run each amplifier? .5 ohm
The size and tuning of the enclosure that it needs to work in? 4.5cubes n at 32hz
The type of music that you'll listen to with it? decaf
Will you be competing with it, or is it a daily usage subwoofer? daily
Is it for competitions only? no
Would you like any special colors? If so, where? no
Upgrades of any sort? Direct leads, carbon fiber dustcap, etc? no
If you have a budget to keep, what is it? no budget
Any other special instructions or requests? no
Where are you located? winters tx
Would you like to send your subwoofer to us, or if possible, to have a rebuild kit sent to you? rebuild kit sent to me
If you are requesting parts, would you like to purchase glue, shims, or solder to assemble them with? glue and shims
thanks guys
The Following User Says Thank You to haze91 For This Useful Post:
TeamPSI (01-24-2013)
Old 01-24-2013, 11:25 AM
TeamPSI's Avatar
0/11 sssss4041
Pm'ed you.
-David Moore
Old 02-09-2013, 04:29 AM
eddiemoua94's Avatar
0/11 ssssss183
can i get a quote for same also? thanks
Old 02-15-2013, 09:25 AM
TeamPSI's Avatar
0/11 sssss4041
Eddie,
Please send your own info to us via a separate PM, service request, or email. Sorry for the inconvenience.
FixMySpeaker
-David Moore
2 12in treo ssx akmarcos12gauge 12" Subwoofers 18 12-18-2011 11:23 PM
Treo SSX 15" dual 2ohm select127 15" Subwoofers 5 10-22-2011 02:51 PM
Treo SSX 15" dual 2ohm select127 15" Subwoofers 0 10-21-2011 12:09 PM
treo ssx 12 dual 2ohm thegreatestpenn 12" Subwoofers 16 07-20-2011 04:20 AM
