4 treo ssx 12s - Car Audio Classifieds!
Old 02-19-2013, 05:33 PM
eddiemoua94's Avatar
0/11 ssssss183
Default 4 treo ssx 12s
Woofer Brand: Treo Engineering
Model: ssx duel 1ohm
Do you have more than one of these subwoofers used in the same installation? If so, how many? 4
How much power does the/each subwoofer need to handle? (RMS power) 2000 watts rms each
What impedance will you need (Per voice coil)? duel 1ohm
The brand, model, and quantity of amplifiers that you'll use? cactus 600.1
The impedance at which you plan to run each amplifier? .5 ohm
The size and tuning of the enclosure that it needs to work in? 8 cubes n at 38hz
The type of music that you'll listen to with it? decaf
Will you be competing with it, or is it a daily usage subwoofer? daily
Is it for competitions only? yes
Would you like any special colors? If so, where? no
Upgrades of any sort? Direct leads, carbon fiber dustcap, etc? no
If you have a budget to keep, what is it? no budget
Any other special instructions or requests? no
Where are you located? ca
Would you like to send your subwoofer to us, or if possible, to have a rebuild kit sent to you? rebuild kit sent to me
If you are requesting parts, would you like to purchase glue, shims, or solder to assemble them with? glue and shims
thanks guys
Wtt: LNIB Treo SSX 15.11 for 2x 12s + $$$ ClickClickBoom Car Audio Trader (WTT) 8 07-12-2011 01:32 PM
2 Treo ssx 12s (d1s) deepsilencer 12" Subwoofers 4 05-27-2011 12:28 AM
1 Treo 2k amp, 1 Treo SSX 18, 6cube box mikeyg402 Car Audio Packages 5 08-06-2010 01:08 PM
FS/T 3 Treo SSX 12s Treo15x2 Broken & Non-working equipment 7 08-02-2010 06:13 PM
[WTB] TREO SSX 12's and TREO AMP godsgift101 Wanting to Buy (WTB) 1 04-29-2010 10:20 PM
