Treo SSI 10s - Car Audio Classifieds!
Old 04-09-2013, 06:42 PM
0/11 ssssssss5
Default Treo SSI 10s
I need 2 recones for 2 treo SSI 10s
Old 04-11-2013, 09:53 PM
TeamPSI's Avatar
0/11 sssss4041
In order to get you the correct parts and pricing to build your subwoofer, we need to get a little more info from you.
Do you have more than one of these subwoofers used in the same installation? If so, how many?
What size does it need to be?
How much power does the subwoofer need to handle? (RMS power)
Is it for competitions only?
Where are you located?
If you are requesting parts, would you like to purchase glue, shims, or solder to assemble them with?
To make sure that we can take care of your needs as quickly as possible, please make sure to answer any questions that we ask to the best of your ability. The more information that we have, the better and more quickly we can help you.
Please send photos of the actual subwoofer so that we can verify the exact motor, frame, and parts spacing. We cannot build drop-in recone kits without first receiving photos of the subwoofer.
If you have any questions, just let us know.
Thanks,
FixMySpeaker
-David Moore
Old 04-12-2013, 01:15 AM
0/11 ssssssss5
It's gonna be in a sealed box the model is SSI the subs are 10s and I need one recone for now and I was how much that's gonna be
Old 04-12-2013, 01:17 AM
0/11 ssssssss5
Rms is 750
Old 04-12-2013, 01:27 AM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
go here
Go there ^...start a new thread... answer all the questions he listed above in list format if u can... such as
Size - 12"
make - treo
model - ssi
The more info u give, the easier it'll be for home to quote you a cost
Old 04-12-2013, 03:07 PM
0/11 ssssssss5
The voice coil is 3 in
Old 04-12-2013, 03:15 PM
Authorized Vendor
0/11 ssss14115
Thanks,
FixMySpeaker
Originally Posted by Jeffhulbert50 View Post
go here, this is fix my speakersforum
Size - 12"
make - treo
model - ssi
Old 04-12-2013, 03:49 PM
0/11 ssssssss5
2 10s
Rms750
2ohm per coil
Ported enclosure
2 1/2 cubic feet tuned at 35 hz
Bass music
Daily usage
No upgrades
Budget is $100
Located in Xenia Ohio 45385
Recone kit sent to me
Old 04-14-2013, 09:48 AM
TeamPSI's Avatar
0/11 sssss4041
PM'ed you
-David Moore
Treo SSP/SSI 10 Husker 10" Subwoofers 5 03-17-2013 07:33 PM
Two Treo SSi 15.22 sslumpin imp 15" Subwoofers 17 01-19-2013 01:44 PM
Treo SSI dking99 15" Subwoofers 3 04-22-2012 04:47 PM
Treo SSi tjjohnson91 15" Subwoofers 6 04-04-2012 02:20 PM
