3HP Neo 10" top request - Car Audio Classifieds!
Old 05-02-2013, 10:55 AM
Pillow's Avatar
Embarrassing Myself
0/11 sssss1099
Feedback Score: 29 reviews
Default 3HP Neo 10" top request
Hi David,
I have a build request for you. Probably similar to SPYs 10" Neo pair that you did for him a while back.
Application: Single 10" sub D2 coil placed IB in the rear deck of a CTS-V. The amplifier will be a PPI P600.2 wired at 4 Ohms bridged producing 600wrms at 14.4v. I'm not gain happy so don't over spider me that she won't wang.
Specs:
Motor: TC 3HP Neo wide 4 bolt 3" coil
Need a basket assembly built for a drop in to the motor. D2 copper coil. I have no idea what basket would work.
Question List:
What impedance will you need (Per voice coil)? D2
The brand, model, and quantity of amplifiers that you'll use? 1 PPI P600.2
The impedance at which you plan to run each amplifier? 4 Ohm bridged
The type of enclosure that it needs to work in? IB
The size and tuning of the enclosure that it needs to work in? Trunk?
The type of music that you'll listen to with it? Mixed, not much rap as it sucks.
Will you be competing with it, or is it a daily usage subwoofer? Daily for SQ-L
Is it for competitions only? No competitions ever
Would you like any special colors? If so, where? No need, silver is fine
Upgrades of any sort? Direct leads, carbon fiber dustcap, etc? **** It dust cap inverted if possible. Normal 8g push terminal leads. Standard stuff.
If you have a budget to keep, what is it? Ahhh, is that a trick question?
Any other special instructions or requests? No.
Where are you located? 20187
Would you like to send your subwoofer to us, or if possible, to have a rebuild kit sent to you? Basket / top assembly ready for bolt on to motor.
If you are requesting parts, would you like to purchase glue, shims, or solder to assemble them with? No.
I can post pics of the motor if you need them. But it is a standard TC 3HP Neo motor "nipple" design.
Thank you!
2007 Cadillac DTS: AT400.1 + 15" Brahma
Daughters 2003 Saab 9-3: In progress!
1979 Porsche SC: Kenwood X-994, PG M50, PG RSd comps.
1971 Chevy C-10: wind noise
Old 05-05-2013, 11:06 AM
TeamPSI's Avatar
0/11 sssss4041
Sent you a PM! thanks
-David Moore
Old 05-16-2013, 02:24 AM
Loyal Member
0/11 sssss1788
Let me know how this works out for u op.
I have a pair or 3hp neo's i need built.
Old 05-16-2013, 12:49 PM
Pillow's Avatar
Embarrassing Myself
0/11 sssss1099
I will keep you all posted on progress. Right now I just need to find an appropriate 10" basket to build on. Once that has been acquired David can start his magic.
Old 05-29-2013, 11:22 PM
Pillow's Avatar
Embarrassing Myself
0/11 sssss1099
Basket acquired here on CACO! Thanks PsychoAccoustics!
Currently in the mail, more to come
(2) 10" lightning audio storm (3hp neo) top assemblies cerwinvega_fan Wanting to Buy (WTB) 13 09-20-2015 10:36 PM
12" Lighting Audio Storm X2.H12.V4 Top (3hp/neo) cerwinvega_fan Speaker Accessories & Parts 8 03-02-2013 03:24 PM
1.5" top plate axis style 3hp iLLsT0LZ Speaker Accessories & Parts 6 10-02-2012 05:38 PM
FS: 3HP Neo Top Plate Steel and Neo Ring Inferno333 Speaker Accessories & Parts 6 02-01-2012 12:26 AM
[TRADED] 18" neo 3hp Lance_aka_64 18" Subwoofers 32 06-12-2009 02:39 AM
