PSI Platform 3 Drop-in needed - Car Audio Classifieds!
Old 05-13-2013, 04:41 PM
0/11 ssssss586
Default PSI Platform 3 Drop-in needed
I have original baskets, but 12 spokes would be preferred.
Do you have more than one of these subwoofers used in the same installation? If so, how many? 2
How much power does the/each subwoofer need to handle? 2500 RMS
What impedance will you need (Per voice coil)? Dual 2 ohm or 1.7
Soundstream 2500.1
The impedance at which you plan to run each amplifier? 1 ohm
The type of enclosure that it needs to work in? (Sealed, ported, bandpass?) Ported
The size and tuning of the enclosure that it needs to work in? 3 cubes @ 32 Hz
The type of music that you'll listen to with it? Rap, Slowed
Will you be competing with it, or is it a daily usage subwoofer? Daily
Is it for competitions only? No
Would you like any special colors? If so, where? No
Upgrades of any sort? Direct leads, carbon fiber dustcap, etc? Integrated Leads, extra spiders, compression plug (maybe)
If you have a budget to keep, what is it? 200$
Any other special instructions or requests? Drop in pre-assembled kit needed.
Where are you located? Cleveland, OH
Would you like to send your subwoofer to us, or if possible, to have a rebuild kit sent to you? Recone kit sent Plz
If you are requesting parts, would you like to purchase glue, shims, or solder to assemble them with? Will order glue from the site, yes
<a href="http://s1200.photobucket.com/user/cl...1_819.jpg.html" target="_blank"><img src="http://i1200.photobucket.com/albums/...-39-31_819.jpg" border="0" alt=" photo 2013-05-12_16-39-31_819.jpg"/></a>
<a href="http://s1200.photobucket.com/user/cl...2_564.jpg.html" target="_blank"><img src="http://i1200.photobucket.com/albums/...-09-12_564.jpg" border="0" alt=" photo 2013-05-12_16-09-12_564.jpg"/></a>
Old 05-16-2013, 12:13 PM
TeamPSI's Avatar
0/11 sssss4041
Check your PM's
-David Moore
PSI Platform 2 15" mytyeerinpie 15" Subwoofers 2 05-24-2013 11:06 AM
PSI Platform 3 Hollow Dog 12" Subwoofers 3 04-24-2013 08:30 PM
PSI Platform 2 18 sherrod833 18" Subwoofers 6 01-03-2013 11:29 AM
PSI Platform 2 brandon_s0854 General Car Audio Discussion & Questions 1 06-20-2012 10:34 AM
Psi platform 2 ItsAjeepThingg General Car Audio Discussion & Questions 5 02-29-2012 04:10 PM
