recone - Car Audio Classifieds!
Old 05-13-2013, 10:11 PM
0/11 ssssss343
Default recone
Woofer Brand: Fi Audio
Model: BTL UFO
Do you have more than one of these subwoofers used in the same installation? If so, how many? I have 1 btl with psi parts
How much power does the/each subwoofer need to handle? (RMS power) min 2500w but will use more power to it carefully
What impedance will you need (Per voice coil)? 2
The brand, model, and quantity of amplifiers that you'll use? 1DD Z-SE amp and 1 ns-1 amp(both at different times of course)
The impedance at which you plan to run each amplifier? .5
The type of enclosure that it needs to work in? (Sealed, ported, bandpass?) Ported
The size and tuning of the enclosure that it needs to work in? Roughly 2.5-3cuft tuned to 38hz
The type of music that you'll listen to with it? rap(mostly), rock, soul
Will you be competing with it, or is it a daily usage subwoofer? Daily (but will compete in street beat though)
Is it for competitions only? No
Would you like any special colors? If so, where? just black
Upgrades of any sort? Direct leads, carbon fiber dustcap, etc? no
If you have a budget to keep, what is it? around $150
Any other special instructions or requests? add in a small psi decal
Where are you located? Houston, tx
Would you like to send your subwoofer to us, or if possible, to have a rebuild kit sent to you? just send in the recone kit please
If you are requesting parts, would you like to purchase glue, shims, or solder to assemble them with? glue(with activator if possible) and shims please
Old 05-16-2013, 12:24 PM
TeamPSI's Avatar
0/11 sssss4041
PUG!!
-David Moore
sa 12 recone jtboxchevy (Sundown Audio) 2 08-20-2012 10:38 PM
sub needs recone audio man General Car Audio Discussion & Questions 1 03-31-2011 08:59 PM
sub recone??? noknok General Car Audio Discussion & Questions 9 03-06-2011 06:18 AM
Going for my first recone MazzaSEC (Fix My Speaker) 5 07-13-2009 04:04 PM
To recone or not to recone? Pioneer TS-W5000SPL BigMoneyTT General Car Audio Discussion & Questions 7 12-04-2008 11:23 PM
