Need recone qoute for Atomic 872 motor! - Car Audio Classifieds!
Old 06-12-2013, 11:29 AM
murderedtahoe's Avatar
Mr. Low End Monster
0/11 sssss3512
Default Need recone qoute for Atomic 872 motor!
I need a qoute for a recone for my Atomic Apx woofer. It has the 818 motor and is 2 ohms. Thanks a lot Dave, I need to get this sub up and running! looking for a dual 2 ohm recone used for daily. this woofer is 3" voiuce coil.
Old 06-12-2013, 11:42 AM
Mr. Low End Monster
0/11 sssss3512
sorry, forgot to mention that this is a 18" subwoofer that uses the 6 spoke basket
Old 06-12-2013, 09:39 PM
Mr. Low End Monster
0/11 sssss3512
Edited first post, found out the sub has the 818 motor that uses a standard 3" coil 4layer.
Old 06-13-2013, 09:41 AM
TeamPSI's Avatar
0/11 sssss4041
In order to get you the correct parts and pricing to build your subwoofer, we need to get a little more info from you.
Do you have more than one of these subwoofers used in the same installation? If so, how many?
Is it for competitions only?
Where are you located?
If you are requesting parts, would you like to purchase glue, shims, or solder to assemble them with?
To make sure that we can take care of your needs as quickly as possible, please make sure to answer any questions that we ask to the best of your ability. The more information that we have, the better and more quickly we can help you.
Please send photos of the actual subwoofer so that we can verify the exact motor, frame, and parts spacing. We cannot build drop-in recone kits without first receiving photos of the subwoofer.
If you have any questions, just let us know.
Thanks,
FixMySpeaker
-David Moore
atomic apx 872 motor psychoacoustics Speaker Accessories & Parts 60 02-25-2014 03:10 PM
FS/FT 2 12" atomic apx 872 Dirtrider4eva 12" Subwoofers 4 05-30-2013 10:45 AM
atomic apx 856 recone - atomic vs rd audio rachidfunaki General Car Audio Discussion & Questions 7 04-14-2011 04:16 AM
atomic and rd recone? mads10bass General Car Audio Discussion & Questions 10 03-10-2010 03:40 PM
atomic ap/spl 10 recone Violence* (Fix My Speaker) 2 08-28-2009 11:21 PM
