Ti Pro 15" top assemblie!! - Car Audio Classifieds!
Old 06-19-2013, 12:59 AM
spl_robb's Avatar
0/11 ssssss571
Default Ti Pro 15" top assemblie!!
Woofer Brand: TC/ECLIPSE
Model: Ti Pro (sw8152PRO)
Do you have more than one of these subwoofers used in the same installation? If so, how many? YES 1 MORE
How much power does the/each subwoofer need to handle? (RMS power) will run on an AB [email protected] OHMS
What impedance will you need (Per voice coil)?qvc 1.2 ohm
The brand, model, and quantity of amplifiers that you'll use? American bass vfl500.1
The impedance at which you plan to run each amplifier? .6 ohm
The size and tuning of the enclosure that it needs to work in? 6.7cuft @30hz for a pair
The type of music that you'll listen to with it?Decaf
Will you be competing with it, or is it a daily usage subwoofer? Daily most of the tinme
Is it for competitions only? Nope
Would you like any special colors? Nope
Upgrades of any sort? nop
Any other special instructions or requests?want to keep the Ti cone and sorround,need TC spiders to match the other sub i have
Where are you located? San diego C.A
Would you like to send your subwoofer to us, or if possible, to have a rebuild kit sent to you? Sent the top aseemblie to you guys
(2)10" Mids (2) HornsD290Py S (2)TW 700Ti all PRV
2 x 18" DSS SAVAGES/2 x SOUNDIGITAL 12K @1 ohm
4 BANKS OF SCAPS/ shca ofc cable wire 4 runs.
Old 06-20-2013, 02:23 PM
spl_robb's Avatar
0/11 ssssss571
Any one there??
Old 06-22-2013, 02:03 AM
spl_robb's Avatar
0/11 ssssss571
Does any one know if David is on Vacations?? a week and no resp
Old 06-22-2013, 07:33 AM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
He will answer here quicker than email which is about a week sometimes.
He gets a gazillion emails. Not for sure but he may be at scrapin the coast this weekend.
Old 06-26-2013, 12:25 AM
spl_robb's Avatar
0/11 ssssss571
Bump for a quote!!!
Old 06-26-2013, 03:36 PM
TeamPSI's Avatar
0/11 sssss4041
We have been out of town for the better part of a week for a big show.
We can rebuild this subwoofer for you, but the performance and cosmetic appearance will be different than the standard factory configuration. We do not have or use original TC parts, sorry.
If you have more than one of these drivers, we do not recommend running a mismatched pair (or more) of subwoofers. We would advise that you use factory replacement parts, or to recone all of the subwoofers to match. We do not recommend trying to mix a pair together.
The average cost to rebuild a subwoofer like this one is $175-225, but the price can vary depending on the exact parts used for your application.
You can either send the entire sub/s to us, or we can send recone kits to you. We do not rebuild the top assembly only due to variances in machining.
-David Moore
12" Custom TC 5200/4hp with Removable Assemblie **Pics** zeuslicious 12" Subwoofers 74 01-30-2014 12:27 AM
12" Custom TC 5200/4hp with Removable Assemblie **Pics** zeuslicious 12" Subwoofers 13 01-29-2013 01:44 AM
Wtb 18" eclipse ti pro top assembly xxxbasshead Wanting to Buy (WTB) 1 07-27-2012 09:50 PM
FS: 15" Eclipse Ti-Pro Top assembly 4" coil jonny101abc Speaker Accessories & Parts 15 06-09-2012 01:17 AM
FS: 18" Ti Pro Top Assemblie for regular 4hp/5200 TC Sounds Motor(not incluided) zeuslicious Speaker Accessories & Parts 35 08-25-2011 02:38 PM
