treo ssx 12 - Car Audio Classifieds!
Old 07-16-2013, 05:14 PM
eddiemoua94's Avatar
0/11 ssssss183
Default treo ssx 12
Woofer Brand: Treo Engineering
Model: ssx duel 1ohm
Do you have more than one of these subwoofers used in the same installation? If so, how many? 2
How much power does the/each subwoofer need to handle? (RMS power) 2000 watts rms each
What impedance will you need (Per voice coil)? duel 2ohm
The brand, model, and quantity of amplifiers that you'll use? cactus 600.1
The impedance at which you plan to run each amplifier? .5 ohm
The size and tuning of the enclosure that it needs to work in? 4 cubes n at 33hz
The type of music that you'll listen to with it? decaf
Will you be competing with it, or is it a daily usage subwoofer? daily
Is it for competitions only? yes
Would you like any special colors? If so, where? blue dust cap
Upgrades of any sort? Direct leads, carbon fiber dustcap, etc? no
If you have a budget to keep, what is it? no budget
Where are you located? 93230 california
Would you like to send your subwoofer to us, or if possible, to have a rebuild kit sent to you? rebuild kit sent to me
If you are requesting parts, would you like to purchase glue, shims, or solder to assemble them with? no
thanks guys
Old 07-16-2013, 05:19 PM
TeamPSI's Avatar
0/11 sssss4041
YGPM!
-David Moore
treo ssx eddiemoua94 (PSI Car Audio) 1 06-27-2012 08:36 PM
treo ssx Reazon (PSI Car Audio) 18 08-19-2010 12:36 PM
1 Treo 2k amp, 1 Treo SSX 18, 6cube box mikeyg402 Car Audio Packages 5 08-06-2010 01:08 PM
[WTB] TREO SSX 12's and TREO AMP godsgift101 Wanting to Buy (WTB) 1 04-29-2010 10:20 PM
