Re hc 18 d1.4 - Car Audio Classifieds!
Old 08-11-2013, 12:28 PM
0/11 ssssss343
Default Re hc 18 d1.4
Woofer Brand: RE
Model: HC
Do you have more than one of these subwoofers used in the same installation? If so, how many? No
How much power does the/each subwoofer need to handle? (RMS power) 1500-2k
What impedance will you need (Per voice coil)? 1.4
The brand, model, and quantity of amplifiers that you'll use? 1 Audio Technix 1200.1
The impedance at which you plan to run each amplifier? .7
The size and tuning of the enclosure that it needs to work in? 4.25cuft tuned to 36hz
The type of music that you'll listen to with it? rap/hip hop
Will you be competing with it, or is it a daily usage subwoofer? daily
Is it for competitions only? no
Would you like any special colors? If so, where? no
Upgrades of any sort? Direct leads, carbon fiber dustcap, etc? direct leads
If you have a budget to keep, what is it? 150 max
Any other special instructions or requests? going on a 6 spoke basket
Where are you located? houston, tx
Would you like to send your subwoofer to us, or if possible, to have a rebuild kit sent to you? no
If you are requesting parts, would you like to purchase glue, shims, or solder to assemble them with? no
Old 08-11-2013, 02:30 PM
TeamPSI's Avatar
0/11 sssss4041
Price sent via PM.
Thanks
-David Moore
