Needing a quote of a custom Zv3 15 - Car Audio Classifieds!
Old 08-22-2013, 06:43 PM
sBass Audio's Avatar
Sonic Boom Auto Sound Src
0/11 ssssss663
Default Needing a quote of a custom Zv3 15
Woofer Brand: Sundown Audio/ TC Sounds ti basket
Model: Zv3
Do you have more than one of these subwoofers used in the same installation?
No
If so, how many?
How much power does the/each subwoofer need to handle? (RMS power)
2k-ish
1ohm
not sure
.5ohm
ported
tuned around 29
decaf, hip-hop, screw
daily
Is it for competitions only?
no
white basket and cone
cf cap
none
Where are you located?
alabama 36870
I will send it in
If you are requesting parts, would you like to purchase glue, shims, or solder to assemble them with?
A d a m
Old 08-24-2013, 04:31 PM
TeamPSI's Avatar
0/11 sssss4041
Check your pm's
-David Moore
Old 08-24-2013, 05:19 PM
0/11 ssssss663
Replied
A d a m
FS: 2 ZV3 Motors and one ZV3 12" Basket Winter_C Broken & Non-working equipment 17 02-18-2013 04:58 PM
Should I sell my two zv3 18"s and get four zv3 12s to get louder. Mnorwood01 (Sundown Audio) 25 06-18-2012 04:13 PM
needing a price quote ben031681 Toolmaker Price Quote Section 4 07-25-2011 11:55 PM
[2] Custom 12's quote EARmeBump (PSI Car Audio) 7 07-25-2011 09:38 PM
custom 18 quote audiobahnfan (PSI Car Audio) 3 07-21-2010 12:56 AM
