Price Quote on 2 American Bass HD 18's - Car Audio Classifieds!
Old 08-27-2013, 05:53 PM
0/11 sssssss20
Default Price Quote on 2 American Bass HD 18's
Woofer Brand:American Bass
Model:HD
Do you have more than one of these subwoofers used in the same installation? If so, how many? 2
How much power does the/each subwoofer need to handle? (RMS power) 2500+
What impedance will you need (Per voice coil)? daul 2 ohm
The brand, model, and quantity of amplifiers that you'll use? 1x AB 500.1 @ .5 ohms
The impedance at which you plan to run each amplifier? .5 ohms
The size and tuning of the enclosure that it needs to work in? 13 cubes tuned to 33hz
The type of music that you'll listen to with it? i demo DECAF alot and daily i listen to everything except country mostly dubstep, rap and metal
Will you be competing with it, or is it a daily usage subwoofer? I do about 5-6 comps a year, i would say 80% daily 20% comp
Is it for competitions only? no
Would you like any special colors? If so, where? no
Upgrades of any sort? Direct leads, carbon fiber dustcap, etc? CF (**** it) dust cap, triple tinsel leads, 4 layer flat wound Aluminum VC,
If you have a budget to keep, what is it? under $200
Any other special instructions or requests? no
Where are you located? Wisconsin
Would you like to send your subwoofer to us, or if possible, to have a rebuild kit sent to you? I will do the re-cone myself, just lookin for a drop in
If you are requesting parts, would you like to purchase glue, shims, or solder to assemble them with? no
Old 09-05-2013, 08:55 PM
TeamPSI's Avatar
0/11 sssss4041
Hello, and thanks for contacting FixMySpeaker.com for help with your subwoofer repair.
This email will give you more information about the process of using our services or getting repair parts from us. We will also be asking you for more information about your subwoofer and the installation surrounding it.
We can build this subwoofer to be run reliably with input power amounts up to 2000 watts rms for most models, but sometimes higher.
There are multiple versions of this subwoofer. The difference between them is in the size of the magnetic gap in the motor assembly. If you want to maximize power handling for your application we would need to first verify the exact size of the magnetic gap of the motor.
What we need from you are photos and measurements from the motor of the subwoofer. Please refer to the .pdf located at http://www.fixmyspeaker.com/pdf/Quic...asurements.pdf for reference. You will need a caliper or other tool that will take very precise measurements. We need measurements that are accurate to within 0.25mm or .010”. Measurements made by a tape measure are not accurate enough to use for our services.
The subwoofer would have to be dismantled (AKA: Cut apart, not working anymore) to take these measurements. In many cases you may need to remove the frame to have clear access to the gap for measuring.If you are not able to take these measurements, we can supply a voice coil diameter that is sure to fit, but may result in a slightly less power handling or peak SPL.
The estimated cost to rebuild your subwoofers is $175 each.
Before we can assemble a drop-in recone kit, we need to get some specific photos of the subwoofer. There is a chance that there could be a variation in the gap height and size for this series of subwoofer, so we would like to at least visually verify the shape and size of the top and inside of the motor.
We will attach some sample photos to this email. Please try to take photos of your subwoofer with the same angle and approximate distance from the subwoofer. The subwoofer will need to be dis-assembled to take these photos.
We apologize for the delay in responding to your request. Our business has been really booming over the last couple of months, and we are receiving 100's of emails and questions per day. We highly appreciate your business, and your patience in waiting for us to get back with you.
If you have any questions, just let us know.
Thanks,
FixMySpeaker
-David Moore
2x American Bass HD 18's D1 PSI recone regizzle 18" Subwoofers 47 02-19-2013 01:58 PM
New price for american bass vfl micro hd!!!! 060gon Mono Amplifiers 26 10-24-2012 05:38 PM
Price quote - bass cherokee bass cherokee Alternator Price Quote Section 1 03-06-2012 01:34 PM
4 LVL 4 18's , American Bass 1000.1 C Pillar Wall constantprojects (DC) 22 05-17-2011 05:59 AM
F/S:: American Bass... New Price.. Hell of a deal. bangin_explorer Mono Amplifiers 11 11-16-2008 10:58 PM
