Rockford fosgate power hx2 3112 - Car Audio Classifieds!
Old 08-31-2013, 07:29 PM
0/11 sssssss23
Default Rockford fosgate power hx2 3112
Sent a service request a week ago. Haven't heard back so as per your instructions I waited 7 days before sending another request.
Woofer Brand:Rockford Fosgate
Model: hx2 3112 (4 inch coil)
Do you have more than one of these subwoofers used in the same installation? 2
How much power does the/each subwoofer need to handle?
1500 watt
2 ohm
DD m2b
.5 ohm
Aeroported
4 cube at 33 hz
Rap and rock
Both but more for competition then daily
Is it for competitions only?
no
no
no
$275
no
Where are you located?
Louisburg Ks 66053
I would like to have the kit sent to me.
If you are requesting parts, would you like to purchase glue, shims, or solder to assemble them with?
Shims
Rockford fosgate power hx2 10 ray60218 Broken & Non-working equipment 2 07-18-2013 12:28 PM
rockford fosgate power hx2 15 assassin1840 15" Subwoofers 1 05-30-2012 10:01 PM
Rockford Fosgate Power Hx2 selton07 General Car Audio Discussion & Questions 2 03-28-2010 11:34 PM
