two sundown sa12's - Car Audio Classifieds!
Old 09-09-2013, 11:54 PM
Brand New Members
0/11 ssssssss1
Default two sundown sa12's
Woofer Brand: Sundown Audio
Model: SA-12
Do you have more than one of these subwoofers used in the same installation? If so, how many? two
How much power does the/each subwoofer need to handle? (RMS power) 1000
What impedance will you need (Per voice coil)? 4 ohms
The brand, model, and quantity of amplifiers that you'll use? soundqubed Q1-2200D
The impedance at which you plan to run each amplifier? 1 ohm
The type of enclosure that it needs to work in? (Sealed, ported, bandpass?) Ported
The size and tuning of the enclosure that it needs to work in? 3.2 ft^3 35 hz
The type of music that you'll listen to with it? rap/hip-hop
Will you be competing with it, or is it a daily usage subwoofer? Daily
Is it for competitions only? no
Would you like any special colors? If so, where? no
Upgrades of any sort? Direct leads, carbon fiber dustcap, etc? Price of direct leads?
If you have a budget to keep, what is it? nope so far
Any other special instructions or requests? not yet
Where are you located? Wilmington, delaware
Would you like to send your subwoofer to us, or if possible, to have a rebuild kit sent to you? send it to you
If you are requesting parts, would you like to purchase glue, shims, or solder to assemble them with? no
What would the price of this add up to in the end?
Old 09-15-2013, 11:22 AM
TeamPSI's Avatar
0/11 sssss4041
We have already responded via email.
-David Moore
3 x Sundown SA12's icewall 12" Subwoofers 10 04-20-2012 06:43 PM
2 Sundown SA12's D4's skavenger 12" Subwoofers 8 01-08-2012 09:23 PM
[SOLD]5 Sundown SA12's FOR THE CHEAP sound_around 12" Subwoofers 26 06-21-2010 02:24 PM
[SOLD]**6 Sundown SA12's FOR THE CHEAP** sound_around 12" Subwoofers 63 06-14-2010 02:12 AM
box help for 2 sundown sa12's Clemsonhacker Enclosure Discussion & Design Construction Help 2 02-01-2010 11:31 AM
