recone Skar vvx10v2 - Car Audio Classifieds!
Old 09-17-2013, 11:04 PM
Slam's Avatar
I slam
0/11 sssss3772
Default recone Skar vvx10v2
Woofer Brand: Skar
Model: vvx10v2
Do you have more than one of these subwoofers used in the same installation? If so, how many? 2
How much power does the/each subwoofer need to handle? (RMS power) 700-800w ea
What impedance will you need (Per voice coil)? dual 2
The brand, model, and quantity of amplifiers that you'll use? 1 ia 20.1
The impedance at which you plan to run each amplifier? .5
The type of enclosure that it needs to work in? (Sealed, ported, bandpass?) port
The size and tuning of the enclosure that it needs to work in? 30
The type of music that you'll listen to with it? hip hop
Is it for competitions only? no
Upgrades of any sort? Direct leads, carbon fiber dustcap, etc? no
If you have a budget to keep, what is it? inexpensive
Any other special instructions or requests? no
Where are you located? Lubbock tx 79366
Would you like to send your subwoofer to us, or if possible, to have a rebuild kit sent to you? no
If you are requesting parts, would you like to purchase glue, shims, or solder to assemble them with? yes all the above
Old 09-18-2013, 10:20 AM
TeamPSI's Avatar
0/11 sssss4041
YGPM sir
-David Moore
Sundown recone in Skar VVX? cgriffin224 (Sundown Audio) 14 08-06-2013 10:34 AM
Dual VVX10v2 ported 3cube 31hz Build dcarcstms Build Logs 8 04-27-2013 01:58 PM
Alternative Skar recone? Sanders0492 General Car Audio Discussion & Questions 12 03-29-2013 02:07 PM
Skar audio vvx 15 and recone andrue 15" Subwoofers 23 09-02-2012 10:56 AM
