Unknown? - Car Audio Classifieds!
Old 10-05-2013, 12:09 AM
0/11 ssssss128
Default Unknown?
I have an unknown motor and basket that I would like to recone.
Things I do know about it:
3" coil
looks to be enough room for an 8 layer coil?
triple .75 slugs
4" from bottom plate to top plate not including pole
mounted to a 15" basket
basket uses a 7.5" spider
motor has 6 and 8 hole mounting options.
Pics:
or if anyone else knows about this motor, please feel free to chime in.
Refs: CACO: 79Bronco, djscrubb, westman995, Inferno333, ta2ed9783, Bigben, Cheebs
CA: RagingXdem0n, Protown, woc47, finalWolf, rtillaree, qcsfinest704, Nineball, DanielSan, a1mcalister1, soccerguru607
ROE: Corey Anderson, Viper118, BigP, StratusRT01, jblanford, Ruger, hotsizzle56, BIGPATIN, bassmech_2000, Splitfirexxx.
Ebay: Neb1fan
Old 10-05-2013, 12:46 AM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7526
Feedback Score: 22 reviews
Something RE
Looks like a lvl 6 from the side
Old 10-05-2013, 10:36 AM
TeamPSI's Avatar
0/11 sssss4041
That's not an RE motor that I have ever seen.
You will need to measure the gap.
http://www.fixmyspeaker.com/pdf/Quic...asurements.jpg
We will definitely be able to rebuild it in any case. We just need to know the details of the gap size.
In order to get you the correct parts and pricing to build your subwoofer, we need to get a little more info from you.
If you are requesting parts, would you like to purchase glue, shims, or solder to assemble them with?
To make sure that we can take care of your needs as quickly as possible, please make sure to answer any questions that we ask to the best of your ability. The more information that we have, the better and more quickly we can help you.
-David Moore
unknown motor timwebb General Car Audio Discussion & Questions 22 06-25-2012 03:52 AM
FS Cheap TC Unknown motor **Pics* zeuslicious Speaker Accessories & Parts 9 06-15-2012 06:14 PM
Hello from parts unknown!!! soldado71 New Member Orientation 0 04-13-2012 07:34 AM
finally.I'm in! I'm trying to contact unknown user 200 [email protected] New Member Orientation 28 03-13-2012 11:22 PM
Unknown 15sub. Looks good armando559 Craigslist Deals 10 01-03-2012 03:09 PM
