Re se 12 - Car Audio Classifieds!
Old 10-13-2013, 10:53 PM
Brand New Members
0/11 ssssssss2
Default Re se 12
This is an older model RE. I have triple stack motor and 12 spoke basket. Can we put something together for this sub?
Old 10-14-2013, 05:01 AM
Brand New Members
0/11 ssssssss2
Woofer Brand: RE
Model: SE
Do you have more than one of these subwoofers used in the same installation? If so, how many?No
How much power does the/each subwoofer need to handle? (RMS power) 1500
What impedance will you need (Per voice coil)? 2 ohm
The brand, model, and quantity of amplifiers that you'll use? Lightning Audio X1000.1D
The impedance at which you plan to run each amplifier? 1 ohm
The type of enclosure that it needs to work in? (Sealed, ported, bandpass?) Ported
The size and tuning of the enclosure that it needs to work in? 2 to 3 cubes
The type of music that you'll listen to with it? Everything
Will you be competing with it, or is it a daily usage subwoofer? Both
Is it for competitions only? No
Would you like any special colors? If so, where? No
Upgrades of any sort? Direct leads, carbon fiber dustcap, etc? Dual sewn leads
If you have a budget to keep, what is it? No
Any other special instructions or requests? Would like for it to play comfortably down low. I will not be throwing more that 1500 watts to it even if I upgrade the amp.
Where are you located? AZ 85143
Would you like to send your subwoofer to us, or if possible, to have a rebuild kit sent to you? Prefer the kit be sent to me.
If you are requesting parts, would you like to purchase glue, shims, or solder to assemble them with? No.
Old 10-16-2013, 11:03 PM
TeamPSI's Avatar
0/11 sssss4041
PM on the way with a price!
-David Moore
