AQ HDC3 (2007 model) 10" 12 spoke - Car Audio Classifieds!
Old 12-31-2013, 06:43 AM
hawaiianmaxx's Avatar
0/11 ssssss862
Default AQ HDC3 (2007 model) 10" 12 spoke
Woofer Brand: Audioque
Model: HDC3
Do you have more than one of these subwoofers used in the same installation? If so, how many? No
How much power does the/each subwoofer need to handle? (RMS power) 5kw+ burps
What impedance will you need (Per voice coil)? D1
The brand, model, and quantity of amplifiers that you'll use? Sundown Audio NS-1
The impedance at which you plan to run each amplifier? 0.5ohm
The type of enclosure that it needs to work in? (Sealed, ported, bandpass?) Ported
The size and tuning of the enclosure that it needs to work in? 1.25 @ 50hz
The type of music that you'll listen to with it? n/a
Will you be competing with it, or is it a daily usage subwoofer? Competing
Is it for competitions only? Yes
Would you like any special colors? If so, where? n/a
Upgrades of any sort? Direct leads, carbon fiber dustcap, etc? Direct Leads
If you have a budget to keep, what is it? n/a
Any other special instructions or requests? Would like it built for a 12 spoke basket
Where are you located? Kaneohe, HI 96744
Would you like to send your subwoofer to us, or if possible, to have a rebuild kit sent to you? Drop-in sent to me
If you are requesting parts, would you like to purchase glue, shims, or solder to assemble them with? Glues to assemble sub
KIDS SAY THE DARNDEST THINGS-
STOP PAYING ATTENTION TO YOUR RATIO IN 4TH ORDERS!!!! Ratios in 4th orders mean about as much of the color of socks you wear.
I never said getting 60 MUSICALLY will be easy did I? Getting 60+ on a burp machine is, sorry to say that but it is.
Old 01-21-2014, 08:33 AM
0/11 ssssss862
If I wanted to order parts a la carte, what specifically would you recommend for my intended purpose?
Old 01-23-2014, 01:07 PM
TeamPSI's Avatar
0/11 sssss4041
We can sell you a kit of un-assembled parts but you would not want to go and pick parts from the site individually and add them to your shipping cart and buy them. It will cost a lot more money this way. We do not charge anything extra to assemble recone kits for customers. We actually charge less when you buy a compiled kit of parts that we select.
We would need to know which HDC3 motor version that you have before being able to give you the exact coil needed. We have two different types, for each motor version.
I actually do not recommend building 10's to burp with 2500w rms.
If you do want to do these builds, we would more than likely be sending you 76.6 x 82x68mm aluminum FW coils, 4 8" spiders, dual sewn leadwire, 10" HD pulp cones and 6" CF dome caps for the best performance in this setup.
-David Moore
Old 01-23-2014, 06:45 PM
0/11 ssssss862
I know this might sound like an unrealistic request, but I am building for a specific local SPL class. I've done a certified 150.7db sealed on the dash with this sub (aluminum coils) on two Sundown 4500D's strapped at 1ohm in my 1997 Blazer. The surrounds finally gave out after years of competition. I was hoping a custom rebuild specific for my use would give me the edge to do 151db+ sealed at the dash. The sub is an original run aluminum coil version from 2007. These are the specs I measured with a cheap caliper- coil: 76 x 84 x 53mm, gap: ID 75mm OD 86mm. Could you PM a price for you to build a drop-in with a list of parts to be used along with a shipping quote? I look forward to hearing from you!
Old 01-24-2014, 10:54 AM
TeamPSI's Avatar
0/11 sssss4041
Absolutely. I assume that it looks just like this?
-David Moore
AudioQue hdc3 motor with 15" 12 spoke Basket BassJunkie Speaker Accessories & Parts 13 10-30-2012 08:53 PM
Hdc3 motor and 18" basket 6 spoke johna7200 Speaker Accessories & Parts 3 01-16-2012 05:34 PM
WTB: 2007 model HiFonics 4ch to match my sub amp beatnbronco Wanting to Buy (WTB) 0 08-01-2011 01:19 AM
WTB: 15" RE SE D4 2007-ish model Ryan1126 Wanting to Buy (WTB) 5 05-30-2010 10:56 PM
