DD 9512g recone estimate - Car Audio Classifieds!
Old 02-08-2014, 01:30 PM
0/11 ssssss586
Default DD 9512g recone estimate
Need a recone for a DD9512g series. I have one already reconed with your soft parts so I would like them matching. Direct leads, stiff suspension, as close to OEM coil as you can get.
Old 02-09-2014, 12:05 PM
0/11 ssssss586
Dual 2
Old 02-09-2014, 12:12 PM
0/11 ssssss586
Woofer Brand: Digital Designs
Model: 9512g
Do you have more than one of these subwoofers used in the same installation? If so, how many? 2 qty
How much power does the/each subwoofer need to handle? (RMS power) 1500+
What impedance will you need (Per voice coil)? 1.7
The brand, model, and quantity of amplifiers that you'll use? single MMATS M3000.1
The impedance at which you plan to run each amplifier? .5 ohm
The size and tuning of the enclosure that it needs to work in? 36-38 Hz
The type of music that you'll listen to with it? tones, rap
Will you be competing with it, or is it a daily usage subwoofer? daily & competition
Is it for competitions only? no
Would you like any special colors? If so, where? No
Upgrades of any sort? Direct leads, carbon fiber dustcap, etc? direct leads, stiff suspension, close of col config to OEM as you can get
If you have a budget to keep, what is it? ~160
Where are you located? Cleveland, OH
Would you like to send your subwoofer to us, or if possible, to have a rebuild kit sent to you? Drop in please
If you are requesting parts, would you like to purchase glue, shims, or solder to assemble them with? I will order glue from your site, unless you include.
To make sure that we can take care of your needs as quickly as possible, please make sure to answer any questions that we ask to the best of your ability. The more information that we have, the better and more quickly we can help you.
Please post or send photos of the actual subwoofer so that we can verify the exact motor, frame, and parts spacing. We cannot build drop-in recone kits without first receiving photos of the subwoofer, and sometimes require photos before an exact price quote can be determined.
dd 9512g recone options Fear Of Theive General Car Audio Discussion & Questions 6 02-03-2014 03:25 PM
Fs: dd 9512g d1 fresh recone 8"cf cap Zooook 12" Subwoofers 11 11-07-2011 10:56 PM
Alternator estimate LEN671 General Car Audio Discussion & Questions 4 12-10-2010 07:39 PM
RE SE wattage estimate Patrick Simmons General Car Audio Discussion & Questions 11 09-15-2008 10:55 PM
need estimate on 1/0 wire waresgaragestereo Wanting to Buy (WTB) 3 09-14-2008 10:39 PM
