Quote mtx 9512 - Car Audio Classifieds!
Old 05-01-2014, 09:24 AM
Brand New Members
0/11 ssssssss4
Default Quote mtx 9512
Woofer Brand: MTX
Model:9512-44
Do you have more than one of these subwoofers used in the same installation? If so, how many?no
How much power does the/each subwoofer need to handle? (RMS power)1k
What impedance will you need (Per voice coil)?2ohm
The brand, model, and quantity of amplifiers that you'll use?soundstream trx1000d
The impedance at which you plan to run each amplifier?1 ohm
The type of enclosure that it needs to work in? (Sealed, ported, bandpass?)ported
The size and tuning of the enclosure that it needs to work in? 4.5cuft 30-34hz
The type of music that you'll listen to with it?rap hip hop country
Will you be competing with it, or is it a daily usage subwoofer?Daily
Is it for competitions only? nope
Would you like any special colors? If so, where?no
Upgrades of any sort? Direct leads, carbon fiber dustcap, etc?direct leads
Any other special instructions or requests?inverted dustcap
Where are you located?78415
Would you like to send your subwoofer to us, or if possible, to have a rebuild kit sent to you? send motor only
If you are requesting parts, would you like to purchase glue, shims, or solder to assemble them with?no
thank for time and info PSI.
Old 05-01-2014, 09:26 AM
Brand New Members
0/11 ssssssss4
size id like would be a 15''
Old 05-01-2014, 10:44 AM
TeamPSI's Avatar
0/11 sssss4041
Thank I sent you an initial quote through private message.
-David Moore
FS: (1) Mtx 9512-44 mazda6i07 12" Subwoofers 22 06-08-2011 10:07 AM
mtx 9512 enlcosure help PLEASE!!!!!!!! pyrothug434 Enclosure Discussion & Design Construction Help 4 04-28-2011 01:16 PM
need help AQ 2200 on mtx 9512 pyrothug434 General Car Audio Discussion & Questions 3 03-10-2010 03:11 AM
