need help on my sub's specs - Car Audio Classifieds!
Old 08-14-2014, 12:56 PM
spl_robb's Avatar
0/11 ssssss571
Default need help on my sub's specs
Hi Dave, i bought a couple months ago a pair of subs from loud and proud
trying to get some more info about the subs.,like TS parameters
coil if its an 4 layer or 8 layer
spider conf(stiff-medium--soft,how many,etc.)
etc.
i know it might be hard for you to remember but its possible.
Thanks in advanced.
the sub is a american bass VFL 18 dual .7 here the pics for reference
(2)10" Mids (2) HornsD290Py S (2)TW 700Ti all PRV
2 x 18" DSS SAVAGES/2 x SOUNDIGITAL 12K @1 ohm
4 BANKS OF SCAPS/ shca ofc cable wire 4 runs.
Old 08-15-2014, 04:15 PM
spl_robb's Avatar
0/11 ssssss571
Bump!!!
Old 08-18-2014, 05:48 PM
TeamPSI's Avatar
0/11 sssss4041
We do not have t/s parameters for them.
If they are the subs that I think that they are, then they have 105mm 4 layer FW aluminum coils, 3 9" medium spiders, dual sewn leadwire, 8ga XS-flex direct connect, 18" HD pulp cone and were shipped with 6.5" poly caps. I would use them with ~2000w rms each.
-David Moore
Old 08-18-2014, 06:12 PM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
Default If all else fails
This works, time consuming, but does work.
How to test T/S easy and cheap
The Following 2 Users Say Thank You to craiggus365 For This Useful Post:
spl_robb (08-18-2014), TeamPSI (08-18-2014)
Old 08-18-2014, 10:34 PM
TeamPSI's Avatar
0/11 sssss4041
Can you tell me about what type of install you are planning to use them in? If you need any advice about enclosure size or tuning, I'm sure that we can help you without having to go through the tedious process of testing the parameters.
-David Moore
The Following User Says Thank You to TeamPSI For This Useful Post:
Old 08-18-2014, 11:45 PM
spl_robb's Avatar
0/11 ssssss571
Excellent Dave,currently running one @1.4ohm dcr with a 5k strapped pair ,don't go nuts on it but handles great,don't underestimate them , w
looking for a daily ported ground pounder once in a while comp. for the 2 18s with 2 strapped 5ks.
thanks in advanced...
Old 08-18-2014, 11:48 PM
spl_robb's Avatar
0/11 ssssss571
double post sorry!!
Old 08-19-2014, 11:10 PM
TeamPSI's Avatar
0/11 sssss4041
I would be trying to get about 6 ft. each for a ported set up. What are you currently running a single sub in?
What kind of vehicle are you using these in? The orientation of the enclosure inside the vehicle will somewhat affect the amount of airspace that we want to use also.
-David Moore
Old 08-20-2014, 12:27 AM
spl_robb's Avatar
0/11 ssssss571
Currently in a 5cuft box @33hz sub up port back on a 2001 Honda crv,right now lacking the lows (32hz and under)shines on the low 40's, car [email protected] 48hz when burping,don't mind loosing my back seat,thanks again.
Old 08-20-2014, 11:45 PM
TeamPSI's Avatar
0/11 sssss4041
If you have the back seat in the car now, how far away from the back hatch is the port? A lot of times, the port itself can be smothered due to lack of depth in the rear of this type of vehicle.
If you want this thing to really kill on the lower end, you will probably just need to attend the box lower. Ported boxes generally don't get much lower than where they are tuned unless the vehicle does a good job in helping out. I'm thinking that your vehicle probably does the opposite though. You might need to send this thing under 30 Hz.
If you are ready to go for it and lose those backseats, are you talking about building a wall or just a big box?
Do you have any photos of the enclosure installed in the car?
-David Moore
18 cubes and 6k what sub's 4ozgloves General Car Audio Discussion & Questions 30 11-07-2013 08:39 AM
positioning sub's in truck jessdabest77 Enclosure Discussion & Design Construction Help 0 02-02-2013 03:48 PM
Will this affect my sub's performance? DevinG17 General Car Audio Discussion & Questions 8 11-18-2011 01:27 AM
Making the switch over to DC sub's need some advice Big Nick (DC) 33 03-08-2011 05:56 PM
